This is a challenging thread for me...and so quite fun. I'm having trouble understanding the point being made unless it is as naive as it looks.
Let me test my comprehension so far? A discontinuous sine wave signal is applied to an amplifier. The amplifier output is a low-pass filtered version of its input, as one would expect. Someone is arguing that the difference between input and output is a "distortion" worthy of this many pages of debate.
I must be missing something.
The latter, it ranks up there with audiophile cable discussions and we all know how those transpire ...
Don't see any measurements in that slide just an anecdote and a leap to a conclusion!
Didn't say measurements were on the slide. I said/meant the engineer giving the talk is someone who I would expect to have taken measurements before saying what is on the slide. When he talks about listening, he qualifies his statements by saying 'sounds,' or similar.
Lots of people refuse to accept the complexity of what happens with cables. For example, attached below is a slide from a talk by an engineer who is very big on measuring.
Theres nothing complex about filtering RF out of a mains cable (any cable), and theres nothing new about RF ingress being a problem. What people refuse to accept this? What they refuse to except is the BS that its hard to deal with, just like the other cable claims. And that 210db PSU filtreing is at what freq.? Just 60hz? That statement is useless.
It is strange that you still do not understand that you have a part of the transient process that is not periodic in the analysis window and the simulator tries to decompose it into a spectrum like a periodic signal. And so in the window on the first period, one part of the envelope falls, on the second - another and then on the descending one. And this is despite the fact that when a real signal is sent from a real source, there should not be a step at the input that provokes such a transition process.It's strange that basic things don't reach anyone.
I'm tired of explaining that the program I'm working with turns the signal of the first period into a periodic signal, regardless of whether there is a phase gap or not.
Here is an example from a textbook of such a signal and a Fourier expansion formula. Everything is painted over 60 years ago, I think there are earlier publications. The first period just characterizes the speed distortions that are not detected by any other testing methods. Spectrum analyzers are not able to measure the instantaneous spectrum of a musical signal - they show an average value - analogous - the average temperature of patients in a hospital.
Distortion meters measure the level of distortion in a steady state.
If someone does not understand basic things, then what Graham unsuccessfully explained in his time, then there is nothing to be angry and offended - pass by, this is not for you.
When evaluating distortions by measuring THD or IMD, we essentially get data on the nonlinearity of the transfer characteristic of the device, that is, nonlinear distortions. And you are trying to measure linear distortions together with non-linear ones in one set, while not even being able to interpret the results obtained, since you did not give any mathematical calculations.
Taken together, these facts put you in the awkward position of a person who does not have the proper understanding for the proper use of the tools at his disposal and tries to measure angles with a caliper instead of a protractor.
How many times have you heard someone say, "A power cable can't have any effect on sound! That's impossible because the wiring all the way back to the power generation plant is nothing special. There is no way the last 3-feet can make any difference."
And what tool then would be the best to really measure a FCD?tries to measure angles with a caliper instead of a protractor
So he didn't measure this effect and just heard it? And how is this helping this thread?
Personally I read that slide that he realised 40 years ago that he hadn't thought very hard about power supplies. Nothing to do with cables.
And there right. If a cable makes a difference its bad hardware design not a bad cable, unless of course its an "audiophile" cable, then all bets are off. And you sound like all that maters is the last 3 feet, which is nonsense.
Bill,
I presume he measured the RF, and the noise floor modulation. It is uncontroversial that some people can hear noise floor modulation at very low levels. So explains Martin Mallinson of ESS. http://www.esstech.com/files/4314/4095/4318/sabrewp.pdf
Presumably, and this an opinion, correlation with the audio signal makes a real difference in terms of audibility. Same way I could hear opamp distortion so as to sort all but one of them in order, when a brass band could have been buried at a much higher level.
The last three feet can be a filter, if designed to be so, well known fact.
And makes no difference in a properly designed piece of gear that has a $2 filter at the power inlet.
Audible radio interference in those days was quite common specially in the evening and during the night when MW-AM-radio station became dominant. Most of these powerful transmitters are out of service now, so this is an issue of the past.
Nowadays disturbances mostly emanate from mobile phones, quite a different story.
- First cycle distortion - Graham, what is that?
