New Stasis front end
These 2 pairs are 60V Vceo rated, if you want higher, look at ZTX457 / ZTX558 which are 300V and 400V respectively. All have around the same HFE.
The originally specified ZTX450 / ZTX550 are 45Vceo.
PCBway don’t play around when it comes making and shipping these out
For those interested, Nelson sent me this email today with regards to max rail voltage for the Stasis FE pcb - as per his design he recommends max rail volts as +/- 60VDC.
Nelson quotes:
"Whatever the transistors are rated at for voltage. I recall the ones I have around here are 120V, so +/-60V is likely the limit. You have to
watch the bias currents as the dissipation on the transistors can get
high. For the big sink Vas parts I wouldn’t want to exceed about 15 mA
at these voltages."
:end quote.
