Aleph J build guide for noobs
I'm going to install thermistors now. Is there anything to gain by installing them?
A common rule of thumb (or finger) is keep the heat sink temperature at 55C or lower for longevity of the output Mosfets. The Papa Pass method of temperature determination is that you can touch the heat sink for about 2 seconds at 55C.
Your heat sink placement does not provide maximum cooling efficiency. Vertical placement of the heat sinks with the fins aligned vertically, and with free space below, above, and around the heat sink is the best. An enclosed space, if you keep the closet door closed, is also not good.
If the heat sinks get too hot, a small fan blowing air across the heat sinks would make a big difference.
The less desirable fix is to lower the bias.
The temperatures are not too bad then.
You have a vent slot between the heat sinks but do you have holes or vents in the bottom of your case? Having air flow through the inside of the case would aid in lowering heat sink temperatures, as the Mosfets and heat sinks as well as the power transformer also radiate heat inward. Also raising the case a few inches above the floor would allow better air flow into the case.
I'm using 2 different types of thermal interface products in this build. The grey colored one almost feels like vinyl seat covering and is used on the PS.. The orange looking stuff is used on the amp boards. My question is would the while aluminum oxide pads be a better choice?
So far heat is not an issue.
Temperature management is rather complicated. AFAIK the silver-mica has better temperature-resistance but because it needs some „grease“ to make thermal connections, you have to add 2 more joints into the equation.
The red stuff is keratherm from DIYAUDIOstore? This is good enough, but of course you’re interested in having the best possible...
How about using a fat pure copperplate (or silver while we‘re at it), and panasonic carbon between it and heatsink? It MAY give you a tiny slight advantage...
Here’s a great redux about all this: Taming the LM3886 Chip Amplifier: Thermal Design – Neurochrome
That's my train of thought Ben Mah. Yesterday was another one of those days. I dissembled the amp to tidy up the wiring.
When it was done it appeared more presentable to the eye but I had another problem. No power to the right and offset was -26VDC.
You know what, after 4 hours fiddling I found the issue. V+ was hooked to a blank spot in the terminal block. Back where i started, a birds nest and I'm out of wire, again.
I second what Ben said.
If your mosfet temperatures are reasonable then you should leave as is.
If your orange pads are the Karatherms from the store then they are excellent. Their
only downside is they are fragile and can be damaged from mounting/dismounting the mosfets.
Al oxide insulators require the use of thermal grease. They are thick enough that
you need to account for that when you mount your parts.
