that second one - 15A - is better than first one - 10A
buy one and stop obsessing
if there is a problem, it isn't in lack of information, it is in your level of appropriate knowledge
when I was young, I meant that basics aren't so important ...... but time did show me they are
there are many books around, more or less informative about amp building basics
one, showing many practical things is M. Jones's https://www.amazon.com/Building-Valve-Amplifiers-Morgan-Jones/dp/0750656956
so, with minimal basics covered, you'll see that entire world of information is available, just looking at pics of finished builds of other people
@ZenMod...so you advise me not to add a switch...thanks
I advise you to learn basics
If you're stuck on switch, how on earth you think to handle everything else, to build entire amplifier?
I mean, fine, I'm Neuro-Surgeon, from tomorrow ........
you're not reading replies properly
you got your answers
- with weak switch, you must use relay inside, switch energizing relay coil, while relay contact energizing amp xformer
- you got confirmation to buy linked 15A switch
- you got schematic how to wire your xformer
I don't see a problem, except that you're expecting that someone here must exactly follow your thinking process, instead that you need to understand replies
- Aleph J build guide for noobs
