Unusual amp from 1987
Since it's built with 2 pairs of output transistors, I expect real 120W
per channel (my speakers are rated 6 Ohm).
Perhaps you could try to squeeze more, but why?
Post #326 contains the schematic 'as built' - 1 output pair shown, in real build 2 pairs were used with
source resistors 0.33 Ohm (0.22 Ohm would be better).
Earlier schematics were slightly different.
One more thing - if you you are going to use more than 1 pair of output devices, ideally they should be matched (for Vgs), at higher current.
2 upper devices should be matched to each other, and 2 lower ones to each other.
Differences between upper and lower devices doesn't matter.
>in real build 2 pairs were used with source resistors 0.33 Ohm
If using more than 1 pair, source resistors always should be used, doesn't matter transistors are matched or not.
Matching will never be perfect...
I wanted to use 0.22 Ohm, but I only had 0.33 in stock.
More pairs - higher values for source resistors.
If pairs are extremly badly matched, and working hot (at high power), they can fail.. (burn like this: :bomb::bomb:)
Using multiple pairs lowers distortions, and lowers output impedance of the amp.
If driving 4 Ohm speakers at high power levels, 2 pairs are recommended.
Moving on - Kletzov amp (1983)
I've been trying to make these maps little bit faster; 15V/us is OK, but would be nicer to have a faster amp.
Here is an attempt: the same configuration for the output as before - Wiederhold style - but with LTP input instead of op-amp.
Thd and FFT look very good - but not as good (yet) as latest Maxim's amp..
Square waves look nearly perfect, it's much easier to tune, and more stable.
Slew Rate is about 50V/us - not too bad for such a simple amp, so this would be an improvement over op-amp based amps.
This is based on amp designed by V. Kletzov, published in Russian Radio magazine in July 1983, so it predates LMK amp.
Стр. 51 журнала <<Радио>> № 7 за 1983 год
This amp here gives better numbers than Vhex I tried to simulate couple hundred posts ago, and this is just 1st attempt.
LatFets are used here just for simplicity of the simulation.
Maxim, perhaps you see some way to make this better?
Perhaps lower LTP current to 1mA per transistor? Shift voltage in some other, better way (not using Zener)?
  • radio_1983_07_latfet.asc
