E130L PP Power Amplifier
So I’m think that I need perhaps 2 CCS boards...
Boards ?? For a CCS only 3...4 components are needed.
These may be useful: 20PCS/Lot 5x7 4x6 3x7 2x8cm Double Side Prototype Diy Universal Printed Circuit PCB Board Protoboard pcb kit|pcb board|double side prototypeprotoboard pcb - AliExpress
Also would you guys run the heaters on AC or DC?
AC is fine. DC for heaters is needed typically when very low level signals are amplified, like in case of phono amplifiers.
As a tubes-only version, I would build this:
Another one only tubes but with CCS :D
The CCS screen resistor (82k) probably need adjusted to get the right current.
Mona
CCS
So 6n6p is dual triode, so you would control each triode with it's own CCS, to balance desired current on each E130 tube? I'll get to the extra tube ahead of the phase splitter soon as gain is an issue here I think.
CCS
I have some IXYS IXTP08N100D2's & 1k pots, which could be implemented they will work at low voltage
Joined 2006
With only 250V max on G2 ( and typical 150V ) this is not a tube for ultralinear or triode mode in push-pull , even if you want . Maybe for single-ended .
So the best option is a stabilized G2 voltage , 150V or so .
Very similar with horizontal sweep tubes , wich have low voltage G2
This tube works in triode like a charm. In PP it gives easily at least 30W at low distortion and over 40% efficiency, try that with a 6L6 or EL34 or even a KT88.
If you want "UL" use part of the output cathode loaded.
Looks like every one is fallen asleep here ;) time to wake up :p
Why not use some nice looking locktal tubes :cool:
One side with, the other without, the decoupling C in the first stage to show the difference.
No delay on the high voltage needed, the auto bias turns on when the first 7N7 heats-up.
Mona
