Thanks...I’m not looking for a substitute to the D3. I just wanted to minimize risk of damage to my tda1541 while testing voltages on the board.
My intention was you place it the first time powering up and check if everything is working as it should be. Then you don't have to use the precious tda1541.[emoji4]
Ad.
Hi guys,
I only get 25.2 vdc from my power supply but it seems to be working fine.. Is 25.2 vdc too low for the d3? What is the optimum range to power the d3?
I’m aiming for 26-27V as I believe Ryan said was acceptable.
Obviously the board power inlet is labeled 26V.
I wouldn’t have had to change anything on the CMx if I had been able to stick with the 22V transformer I initially tested it with.
Unfortunately, it took up more space than I wanted so I ordered a Triad VPT48-520 which put out 27.5V after the CMx with a 200 Ohm load.
I felt that was too high and had to start playing with R4 and R5 to try and get it to an acceptable level.
After I tested my CMx board a second time with 22 Ohm paralleled with a 100 Ohm I actually got about 26.3V.
There is obviously fluctuations in my mains voltage causing it to swing. It appears to be centered on about 26V so I am leaving it for now.
A question about BOM.
What determined the choice of the KA caps? Were other caps auditioned in their place or was the slimness their main attraction? The reason i ask is i have no first hand experience with KA and the internet opinions about them are controversial at best.
Try whatever caps takes your fancy. 😉
D3 input voltage
The voltage input limitations are set by the amount of heat dissipated by CC1 and V1 . I usually aim between 26V and 27V, but I have used up to 28V with no issues as long as the temp on CC1 and V1 are not too far above around 55 Celsius.
I would not recommend going lower than 26V - as this was the voltage that I used in the simulation to get good performance, anything lower than 25.5V may affect performance.
So, no special considerations then. Thanks!
I liked the small form factor, I was severely limited by space with my design and I didn't want to do a full redesign.
Edit: They also performed just fine when tested with a recording at -60dB
Ryan,
My package arrived today in SF Bay Area of California today!
Looking good. Thanks for all you do Ryan!
Aguaazul
You're welcome 🙂
I was playing around with a variac and varying the input voltage to the Dac board. Absolutely correct about CC1, the temp gets to high quickly. I’ve gone as low as 24.5vdc, below 24.1v the three voltages start to go out of regulation. If the simulation was based on 26v, try to be within -0.5/+1.0 of 26v.
I thought KA was chosen because of its good performance regarding low leakage?
Yes you're right, this is the most important factor. Which is why I tested them with a -60dB recording. If there was any leakage you would hear a distorted sound at -60dB.
thanks to all that helped.. I will adjust the power supply to the recommended voltage.
I've placed an order for bisesik transformer for the d3 and should hopefully get it by the end of this week. will give an update on how this works out.
Does somebody have some tips where to buy the components for the D3 pcb?
Living in Europe.
Thanks, Ad.
Living in Europe.
Thanks, Ad.
if i use a 200ohm 5w resistor to test my charge multiplier psu, then the voltage climbs slowly up to 24v and stays there. it needs about 3-4 secs to reach 24v. Any idea what i did wrong ? Or is it a wrong r at the end (15ohm).
The transformer is a 24-0-24 24VA one, so that should not be a problem.
A slow ramp up voltage is a normal capacitance multiplier psu characteristic.
Ok, so not i should try different resistors between the capacitors (15ohm) ? Lower than 15 ?
- Group Buys
- DIY TDA1541A PCB "D3"
