UGS-muse preamp GB
Hi Gionag,
I’m sure Eric and Alex can give more details on the input impedance matching than I can.
In the meantime, the way I adjusted it in my implementation is described here: <<UGS - Muse edition - Page 25>> - 30058092 - sur le forum <<Amplis et Preamplis>> - 1056 - du site Homecinema-fr.com
Basically, without any module and without power, adjust the trimmer for each leg of the circuit in order to get the same measured resistance between AGND and the corresponding test point. I remember setting mine to 12K, but not sure if another value would be more optimal.
Hope it helps
that was gold... thankyou
Hello,
yesterday i was able to complete the assembly of the uC board.
fitted with two OLED.
was able to push the firmware into the mcu. that, BTW, after latest windows 10 update seems to have broken the Dfuse utility.
The alternative, and the recommended utility to use from st is the "Stm32CubeProgrammer".
It support's perfectly usb dfu mode, but no longer read the .dfu file.
the .dfu is easily convertible to .bin or .hex (that is supported from the new tool by the utility "dfu file manager" that came with the Dfuse demo utility.
if someone needs the converted bin file...here is the latest .dfu available from alex, converted to hex
Dropbox - UGSMusePreampPCB1.2_v2.9.3_00.hex - Simplify your life
thanks
M.
Good job Gionag 🙂
Right I should upload the .hex file as well now that indeed STM32CubeProgrammer is the right tool to use (I am still using Dfuse on my Win10 PC BTW...)
Anyway this binary is not the latest one and thanks to Paul M trial & feedback I am going to release very soon a new one fixing several display bugs and adding new modes to control the trigger & bypass.
... (I am still using Dfuse on my Win10 PC BTW...)...
I suppose you have installed the dfuse before the latest windows 10 update.
If that was so, then it continue working.
... Anyway this binary is not the latest one ...
I have used the latest .dfu file available on the hcfr thread. is there a new file that i am not aware of that is already uploaded somewhere ?
Thanks !
Changing the shutdown message is already possible since the beginning.
By the way the latest default shutdown is "bye bye ..." only.
Then Paul just confirmed me that the latest firmware v2.98 I did is working well now and seems display bug free on OLED and VFD.
I need now to spend some time on the dual encoder control for those who need this.
This is working well on my DAC already so is not difficult to integrate, just need the time to do it.
That will be the last upgrade I will do unless of course a bug is found by one of you (and then I will fix it).
Hello,
Any encoder should work regardless the number of steps with the way I implemented the software.
I am doing basic denounce on that portion as I am using an optical encoder which does not need it but do let me know if mechanical ones produces glitches and I may work on something more robust.
Then yes the preamp configuration menu allows to divide the steps by considering only every 4 steps.
