Dartzeel amp schematic - build this?
The problem with simulations is that you get a flood of numbers and lose insight. I know what I'm talking about: I did mathematical modeling in the era of IBM1130. Often it pays of to investigate the problem by using common sense and basics of physics. Now, use your numbers and verify my results which I have obtained easily by simple calculus and are more accurate i.e. can be validated with measurements.
Regards🙂
According to my measurements and calculations just R19 and R20 require higher power rating: 600mW.
My reasoning is as follows: voltage drop across these resistors is about 4.5V. This indicates that current is 115.4mA, i.e. P=519mW -
Am I correct?
No. R17 and R18 also have higher steady state dissipation.
But once signal is applied and amplified you have to consider AC dissipation as well. Resistors affected are the NFB 7.5k as the full output is developed across 7.5k + 360R and the resistors at the output transistors bases as the max output current divided by beta flows through the bases.
At one of the Russian technical forums, a comparison was made between radio engineers with great audio experience. Takman rey showed their best side, PRP is in second place, dale is even worse. But personally I think they are all good. It's a matter of taste. Then I will unsubscribe when I collect and listen.😉
Reactions: matsurus
Well, audiophiles are like enologists. They both rely on their own predudices. Tongue tastes what it wants, ears hear what they want. And yet, both renounce measurable facts because facts are usually in conflict with their opinions/prejudices.
Echo chamber effect is to blame. Give them vine/equipment in a bottle/box without a label and ask them to distinguish vine from vine and resistor from resistor. Enologists have better chance to guess, I think.
I will persist with Vishay.
@Erlend
I have a good news for you: look at the image below from review by John Atkinson. His measurements are consistent with my measurements of the clone NHB-108. Note that he hasn't even bothered measuring below 10Hz.
This indicates that we have built pretty much fine amplifiers.
I have 2 clones of KRELL KSA 5, the first on CCF 55, the second on RN 55, play equally well, but both are bright, I use it as a headphone amplifier and a preliminary to Dartzeel. So I decided to try something new. Here on the forum is my friend from the USA, which has 2 versions, one on Vishey, the second on PRP. Maybe he will write how they sound. I will not convince anyone, we listen with ears.😉😀
Agree with those Russians but it all depends on the construction. The Dartzeel needs something brighter then Takman.
Perhaps,
There are two metal film resistors we can use directly:
Vishay CCF024K75FKR36 Metal Film Resistor - Through Hole 2watt 4.75Kohms 1%
Vishay CCF026K80JKR36 Metal Film Resistor - Through Hole 2watts 6.8Kohms 5%
As suggested elsewhere in this conversation, the remaining 39R/5W could be attained with two parallel
CPF282R000FKE14 Metal Film Resistor - Through Hole 2watts 82ohms 1% 100ppm
But, first, I will measure real power demand with +-42V rails.
Perhaps, analog_sa is right: why would we follow exaggerated wattage ratings. And why should we build a 100W to listen to it home at just 1 to 2 percents of its capabilities. Perhaps the Chinese have exaggerated these +-55V rails.
Lets measure.
Have a pleasant nigh. I think I should go to bed now.
Bye
cpf 3 4.7k is enough
Thanks Sensation45. Your suggestion is welcome.🙂
Meanwhile, I have made some calculations and found out that there is no need for exaggerated desin margins which involve selection of wirewound resistors.
Now I have decided to use 1/4W resistors everywhere except 600mW for R17, R18, R19, R20, R25 and R26.
Measurements indicate that widely addopted excessive power ratings are unnecessary. Just take a pencil and a sheet of paper and calculate from the values in the schematics. It appears that the designer/cloner had some plans in his mind and has built in design margins but later has abandoned his plans and forgot to go back to lower rated resistors.
I will inform you if I get some smoke from my PCB with much smaller resistors.😱
