100W Ultimate Fidelity Amplifier
MM2R
not tested there could be errors
Joined 2018
You must test preamp with amp connect to output, amp input impedance load preamp with 22k... P30ZF DC offset is very good for circuit without global negative feedback.
Yes, that is better with the amp connected to the preamp output, thanks Mile.
Gerbers attached
PS: i still have one spare available
  • Gerber_PCB P30ZF Version 2.2.zip
