DIY biamp 6-24 crossover
to Peppeninno #296
Not so easy to get 80-90 hz in the low-pass with a 12dB slope
without
-big phaseshift (150deg.)
-Q-factor around 0.7
-dampingfactor in simulation: 0.68
I simulated with 150nF and 68nF / 20kOhm and 14kOhm.
:confused:
I think you have to try and listen
Greets
Dirk
But you are playing with the electric simulation. You need to do it with the acoustic responses in the end. With subwoofers it is also a matter of where you place them in the room. In the end it will rarely be the strict Butterworth, Linkwitz-Riley or whatever. That is also the good point with this crossover. What does the frequency response look like for the bass and the rest?
to RogerGustavsson #303
I fully agree with you. These are only simulations.
Peppennino has to try and listen. Moving the subwoofer closer / away from listening position, perhaps reverse polarity at output of amp,....
Loudspeakers have that different behaviour.
Testing, adjusting and listening is part of the fun! :D
Greets
Dirk
As I wrote, it's a Pass' SLOB, not a separate sub
Clearly the Eminence is in the SLOB, but is it 2 units - or a single? ripole?
And in that case, the Eminence already have a high Q, actually much higher than needed for SLOB, Peppennino are you running it with a coil in series as well - which is often part of the recipe?
Depending on the slot size you will have a quite big resonance peak - most likely somewhere between 200-350Hz.
It can be somewhat reduced by a non symmetric slot wall, but even so I have not been able to get rid of the peak. And you very likely will need more than 12dB to get it properly squared away ;)
Anyway - as Roger implies it's far from trivial - and SLOB does not make it easier. I would not spend too much time on fine-tuning the simulation before doing the first measurements - and eventually feeding these back into the calculations. There is quite a tolerance on most units which can shift results quite a bit.
I use Faital 15PR400's in SLOB, the datasheet: Fs = 35Hz, actual value 32(->28Hz run in) in SLOB it's down to 18 (->16Hz run in). And these are proper high quality pro units!
