F3 Builders Thread
I'm mounting my Lovoltechs on top of the heat-sink flange. Out-of-the-box their legs aren't long enough for this, so they were shortened to just that needed for the horizontal bit, and then resistor leads were added for the vertical bit.
There's a brass bar behind the screw which is the same height as the JFET. It's stuck down with a bit of superglue to make assembly easier.
Then the JFET goes down with a bit of grease and mica and a cap screw with a conical washer and then a fender washer.
The MOSFETS mounted in conventional fashion:
While running it in it my benchtop PS claimed it was consuming 1.61A.
Temps measured with IR thermometer:
c-multiplier MOSFET case: 48ºC
CCS MOSFET case: 76º
heatsink nearby: 65º
cascode MOSFET case: 72º
JFET case: 44º
heatsink nearby: 40º
outside of heatsink at centre: 44ºC
Offset was at 21V so CCS should be burning 30W for a die temp of 101º.
All seems good enough to build the other channel?
Hi Jeff,
Just want to know how big is the washer you used in mounting the LU1014D?
When measuring the Vgs of my LU1014D, I got the result of 1.34V. Is the voltage too large?
Just want to know how accurate of the 1 ohm resistor value will give the correct voltage value? My resistor was measured 1.1 ohm, not exactly 1 ohm. But I doubt that a 10% difference will give a 30% error on the voltage? What do you think?
