F3 Builders Thread
Here's an unpopulated board if it helps. Had a spare JPEG_20200805_221737_8527353215632886475.jpg
Bad diode, bad cap, or short.
I don't think it's a bad resistor cause you have current flow where there shouldn't be any regardless of the resistor value.
You could have a short in parallel with the resistor so it's measuring low.
Did you also replace the mosfet Q5?
Ah dammit.
I replaced q5, and it was all great! Measuring well, powered up slowly, all good.
Then while checking voltages, I managed to kill q2. I replaced it, and now the pins of q3 are starting to smoke.
Need to leave it alone for a night or two, then regroup.
