Amp Camp Amp - ACA
yes, it is so good on certain speakers that even prototypes have an almost too long life ; )
ACA has best "swing/timing" with those cheapos, better than V-Fet. It is long time since I heard an Aleph J, but I recall the trebles with the J not that lively. But could be wrong there.
best,
stefan
Nice and clean boxes Stefan. I like the stands too. Did you use any BSC with the aca?
Some years ago I built a Cheap Trick 269, similar as Stefan pictures. They sounded surprisingly well with tpa3110. Limited bass but very entertaining and clean sound. And less than 50€ everything!!.
I keep the drivers, maybe I must try again with my aca and M2 .😀
Hey guys,
New to this forum as I just received my ACA 2018 kit today. I was going through the components for the boards, and labeling the color coded resistors, and noted that I have two 33.2K ohm metal-film resistors that appear to be extra. The color code is orange orange red red brown. I've identified and labeled all the other color-coded resistors on the schematic and the components list, but I cannot find a 33.2 K ohm resistor on the schematic or in the list of components. Is it possible these two resistors were added accidentally?
Sorry if this question has come up previously.
Cheers, Stephen aka PC
Variac and the Boyz have been hard at work. Recently we ran some curves
of the parallel and balanced versions:
Tony, I remember np asking when someone was going to make an amp worth 4 ACAs per channel. All you have to do is make another chassis with 4 and you win!
i am making one now, 48vdc, 4 smps psu, 4 ACA channels, and based on the data above i will be making it balanced bridged type using XLR's....i may even throw in a tube buffer to give it a tube flavor...
i am using the conrad engineering 35cm heatsinks....will post once set up..
What is the power output of a parallel 24V ACA into 4 ohms?
The power into 4 ohms would be twice that into 8 ohms if you run them in parallel.
Parallel connection only gives you more (double) the available current, the voltage output is still the same.
For example.
1/ 9 volts rms output into 8 ohm is 10.125 watts rms. The load current is 1.125 amp.
2/ 9 volts rms output into 4 ohms is 20.25 watts rms. The load current is 2.250 amp.
