L-Adapter
Hi @Salas
Few months ago I asked you regarding a High Power version of the Ladapter. I end up not buying it, I needed more power.
With the proliferation of diy High end music servers (generally i5 or i7 Pc’s) we are in need of High power ac-dc Psu. The idea is use it with Dc-Dc atx adapters.
Are you planing to design a 200-300w (9 to 22v) version of the L adapter?
Antônio
I built mine lately,in 5 volt version to power my Logitech Squeezebox touch.guys the difference with the stock smps psu is night and day.i can surely tell you that if you have a Squeezebox touch you have not heard it without L adapter.now,i can clearly hear my Benchmark dac3, through coaxial.salas bravo!
My speakers are pmc ib2i and are like magnifying glass to the truth...
Hey Salas, many thanks for what is poised to be a great PSU option for the RPi4.
I have a few boards on the way, and as I am slowly gathering parts (I am having the PSU built by someone much more experienced than myself), a question:
I have on hand an encapsulated, double shielded 2 x 12V @ 50VA toroidal transformer. I understand that within the guide you recommend 9V transformers for a 5V (well, 5.1V output) - but is there any chance to use this transformer?
My initial plan is to have 2 PSU's built in the same enclosure with the same transformer - one for the RPi4, the other for an optional USB isolator if the need arises.
I'd like to be able to use this transformer, especially since getting a new one will delay the build significantly, but do not want to compromise on the PSU.
Any thoughts? Thanks!
