Thank you zman01 and Dave, what a great design! I’ve never received so much beautiful music for my time and money. You’ve ushered into my world an extraordinary thing! Thank you 🙏
Tubes need food
The amps are two stage, 12BH7A drives a 45. They are cap coupled with fixed bias. I use a grid choke. The big separate power supplies are overkill but the goal was low DCR and by gum it’s very low. Each tube has its own DC regulator so it’s silent. Beautiful blackness and surprising speed, that’s what the XLs are great at, fast and dynamic, no blurry edges. I always just thought the XLs would need more that two Watts. They Don’t!
Hi All-
I built these using the 10p (which are fantastic). Not that I'm in any rush but would these work? The measurement I see is about 5.7 inches across, so physically they should. They just look gorgeous.
One Pair | 6.5 Inch Full range Hi-Fi Speaker Driver | Bakelite Cone | Superb Mid | M6 - Lii Audio, unique speaker, amplfier, quality and cost-saving parts for HiFi DIY
Probably. High qt likely means lots of damping needed below the driver. High Vas might make it more suitable to Joan.
dave
Is that a Lii audio driver...ooo i think it is...lately they are getting lots of attention from different parts of the world. Any idea how do they sound?
Has anyone tried Alpair 11ms in FHXL enclosure? How do they sound? I think the cabinet must need some modification... Or just mounting hole modification will do the trick?
It is Lii Audio. I haven't found much if anything about the M6, more info on their 8" and 10" full range models.
If they would drop in with some mods I would be interested, but at roughly the same price point as the 10p I would not expect them to be a significant upgrade if they are better at all. They are lookers though!
The look back at the old bi-flex is indeed intriguing. This is the most interesting Lii Audio i have seen yet.
dave
is the 5-degree tilt in the front baffle of fhxl just for driectivity purpose or does it have any other sonic properties like decreasing standing waves inside the enclosure.
thanks scott.
im trying to get birch ply with good grade. but it seems birch ply is not easily available in south of india. is it okay to use 19mm 100 gurjan core plywood with minimum void and a specific gravity of more than .68 and has 13 layers.
Lots of plies and low or no voids along with quality construction is whatyou are looking for. Typically the less it weighs the better.
Got a link to this plywood?
dave
dave
I have the link but i talked with the guy via email so im nt sure which plywood variant from the site is the one he was offering me. specs he gave me is specific gravity of .7 g/cc or more, 13 layers of ply, 19mm thickness and made from 100% gurjan which is actually a heavier wood.
The link Plywood Sheets | Particleboard | Boards India | Kerala
I checked the specific gravity of baltic birch and it was .68 g/cc. Hence i was having the impression that sg of .68 or more is better. Good that you told me lighter is better
The pictures look good, the differences look most like differences in face veneers, which are to the largest extent cosmetic.
As expected teh dimensions are actually metric (4 mm, 6 mm, 9 mm, 12 mm, 16 mm, 18 mm, 22 mm, 25 mm, 30 mm, 40 mm), FHXL can be made from 16 and a thicker baffle (18/22), or all using the thicker stuff.
This page: Commercial Plywood Sheets | Manufacturer | Kerala | Boards India
dave
dave
- Full Range
- Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
