Better to ask questions before starting work. Measure twice, cut once.
I like that
Yes it canhi karmenko , can irf640 and 9640 be used in fh9? 😕😕
Yes it can
Thanks karmenko , will post pics once i make.
Dear Gannaji,
could y please share your mail ID
dhanya_els@yahoo.com
SURESH, TRIVANDRUM..
9846010894
9846010894
Hello gents. I do apologise for being off topic. I saw a video on youtube with TP2 tone control. Can someone please send a link with the post/topic of TP2 ? I have tried to search for it but couldn't find a clue.
Best regards.
Best regards.
PSU10R
Best regards.
??????????????? ????????? APEX TP2.
Mr. Mile,
with 15VAC-0-15VAC , can we get +12VDC/0/-12VDC with above circuit?
Would BD139 require heatsink for say 30-50mA current?
regards
prasi
regards
prasi
PSU10R
Regarding this circuit, what will the output voltage be if my input voltage is 45-0-45vac? Is this adjustable?
Its in Russian 🙂
I saw that video on Youtube., Is there a chance of getting the pcb layout for for toner transfer method for the TP2 preamp?
And to Mile, thank you for the wonderful shared you allow others to use. It is much appreciate.
Mr. Mile,
regards
prasi
With 15VAC-0-15VAC , you can get +15VDC/0/-15VDC, this is Low Drop Output Regulator. Output voltage can be very close to the DC input voltage.
You can set output from +/-45V to +/-60V with 45-0-45vac input voltage.
Thank you sir, appreciate it. And output current? Is that dependant on input current? I would like to use it on your APEX AX14
Maximum current is 10A, you can use it for AX14 stereo
- 100W Ultimate Fidelity Amplifier
