JFET-only Circlotrons without negative feedback
hi
UJ3N065080K3S model is already in FULL_JFET.txt, but i don't know if it's a good idea to use a mosfet in the diagram
but i donc know how to create a Jfet subckt
yes R6 need to be adjusted but the quiescent current is not a problem.
In simulation the gain is too high, my 2sj103 model should be wrong
Hi!
In the next thread there are 2sj103 models (JFET and MOSFET SPICE models). It seems that this is the only 2sj103 model that can be found.
.model 2SJ103Y PJF(beta=1.053m vto=-1.342 is=1n cgd=8.0445p cgs=4.9555p lambda=34.8 mfg=TOSHIBA)
.model 2SJ103GR PJF(beta=2.283m vto=-1.342 is=1n cgd=8.0445p cgs=4.9555p lambda=16 mfg=TOSHIBA)
.model 2SJ103BL PJF(beta=5.092m vto=-1.342 is=1n cgd=8.0445p cgs=4.9555p lambda=7.2 mfg=TOSHIBA)
I also found such models:
.MODEL 2SJ103 PJF(BETA=2.197M RS=76.76 RD=76.76 BETATCE=-.5 LAMBDA=735.3U VTO=-2.037 VTOTC=-2.5M CGD=18.95P M=.5045 PB=.3905 FC=.5 CGS=17.02P ISR=38.48F NR=2 IS=3.848F N=1 XTI=3 ALPHA=10U VK=100 KF=1E-18 AF=1)
.MODEL 2SJ103BL PJF (BETA=898.438U IS=10F RD=200 CGD=11.9398P CGS=14.4P)
.MODEL 2SJ103GR PJF (VTO=-1.62622 BETA=16.1875M LAMBDA=1M IS=10F RS=186.826 CGD=13.2918P CGS=14.3694P PB=806.232M KF=0.001F AF=500M)
HI
With the difficulty of finding input jfets, I thought why not bipolar, so I tried to simulate this one
Jpatay, this is the amp so I spoke to you in December, but I just invert the schematic and put the Power Jfet that you proposed
HI
Hi Seb!:wave:
It is very good that you have completed this circuit. It would be nice to collect and listen to it.
And also check for thermal stability. Spring. I don’t want to do anything.😉
Measured its stock SIT-JFET KP802A (КП802А).
A total of 114 pieces, 87-92 production years.
Began to disassemble the "fours".
In the attachment is a table of those with the highest drain current initial, the tip of the iceberg.
Schedule for the "average" of the four transistor 57 / 98 - 36 / 37.
Average parameters calculated: Ri=(15-5)/(1,89-0,747)= 8,7 Ohm, S=(2,27-1,49)/(1,5-0,5)=0,78 A/V, u=RixS=6,8 units.
Output impedance of the common-drain amplifier:
1/S=1,28 Ohm.
It is seen that the output arm voltage should be kept 18-19 V. For these numbers.
