Second Stage. Paralleling transistors ok?
Hi folks,
I'm working on another amp and have some decisions to make around the second stage. I could go the MJE340/350 (stand alone or darlington/ compound / cascode) but I like the idea of faster & more linear devices. Finding one that will take a bit of heat is difficult, hence my question; Is it ok to parallel them. In this example it is T9-T12 and I'm thinking 2 each of 2SA1381 & 2SC3503.
Naturally I will match them so I feel it's ok, but have I missed something?
Cheers
Q
Hi Quasi,
Looking at your circuit, your target is about 30mA as VAS bias current. I don't know what the rail voltages are, but suppose they are 50V; this means a power dissipation of 1,5W. This will remain offcourse, also with 2 devices in parallel.
Looking at the datasheet of the 1381/3503; Ft is max and you are in the lineair region of the transfer curve (Vbe/IC).
I would use 1 device with sufficiënt heatsinking.
But in using 2 pairs, I don't see a problem. IIRC the Titan 2000 from elektor uses parallel devices in the VAS, you should look it up.
BTW: have a look here, I think you can have problems with stable VAS currents.
HEEEELLLPPP : M. Randy Slone Mirror Image Topology Construction - Troubles
Maybe.
Putting so huge Miller cap (2x47pF) will greatly sacrifice slew rate for keeping amplifier stable.
Try to use external compensation and relatively small VAS current.
The goal is to lower reverse capacitance from the high-level point (VAS output) to the low-level point (IPS output).
It's better to use cascode there, it will remove that coupling by capacitive coupling cascode device base to ground.
Maybe.
Small VAS current equals lower gain (higher VAS degen. or lower IPS collector resistors) = option to reduce Cmiller. But it depends on what the VAS has to drive, not known while no full circuit available.
Lowering reverse capacitance equals increasing Vcb, with a cascode you will have the contrary, not? With a cascode this capacitance is offcourse stable and not fluctuating with the VAS output swing.
Just thinking here...I’m definitely not in your level of experience BesPav.
Your supply rails are +-85v for this stage, so that you will build a high power amp.
For a high power amp, we usually have 3 more stages pre-driver, driver and final power output, therefore you mention this stage actually no need using too high driver current, a 7mA~10mA is quite enough for it.
Now had a look at LTSpice but can not see how you would arrive at a nice schematic drawing like in post 1.
Hi as_audio
I hadn't finished the "nice" drawings when I replied earlier. Here they are comparing two different 2nd stage configs. Note; some of the component values are not finalised.
Cheers
Q
Other members now post the LT Spice .asc file of their schematic. This can be zipped with any special parts models used and downloaded by readers and examined in their own LT Spice program, just like other files they may generate. A really amazing and useful time-saver.
Hi Q,
Nice to see you here....... it's been a long time, and we are all a few years older!
Good circuit, although not a quasi!
Questions:
1. Have you done the sims with and without the two CCSs for the input LTPs? Using a resistor there will decrease PSRR; but will it ruin the performance?
2. You'd put two transistors in series for the VAS. What do you think is the advantage, and which transistor will you choose?
Hugh
