Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Here's an article about dual versus a single driver attached to one horn. It doesn't seem worthwile, but the manifold (adapter) looks like a huge bottleneck with its sharp angles and pinched throats.
For dual-Axi2050 duties, a traditional WE/Altec type short exponential manifold might work better, perhaps with vanes near the exit.
Dave Gunness did manage to get the HF to work quite a bit better on his EV MTA-22 manifolds than the traditional WE/Altec, but as is obvious in Pat Brown's test, the outcome is not very good when compared to a single driver, even before considering the increased distortion generated at high drive levels.
I was very glad when finally got a return credit for the eight MTA-22 purchased around 1991.
As far as multiple drivers on a single horn, for Camplo's application there would be no need to double up the HF, just use appropriate low drivers sharing the horn.
Art
Expensive without a quantity is only "feeling" 😀
Here is link between quantity and "feeling" :
"The finest aluminum domes are made by Radian in the United States of America with a alloy nuance developed by Mitsubishi in order to build Japanese military planes during the war"
Yep I'm familiar with the origin of Duralumin, its applications and the Japanese successor: (Extra) Super Duralumin.
When crossing as low as 400-500 Hz, small woofers are not required, 15" have been used with excellent results.
Using commercially available horns that already have the desired dispersion makes "pulling it off" a lot easier than making the entire multiple entry horn from scratch.
That is easily the simplest solution to the problems stated herein. Very nice idea. Any of something like this that you could show?
Art
Agreed, but I guess the HF extension was more related to the use of modern drivers than to the horns.
In 1934 WE engineers already got the 594A flat to 13k, controlled within 0.25 dB and with minimal group delay.
It is known WE modified a few 5.. drivers to let them play up to 20k for some of the experimental setups.
803729d1576912797-western-electric-horns-594a-erpi_small-jpg
803730d1576912797-western-electric-horns-26-jpg
And I really enjoyed your reviews of the Dutch&Dutch 8c and Kii Three, that I read only recently. Two of the most comprehensive loudspeaker reviews ever.
Big thumbs up!
Part of the 594A's secret sauce, still not fully decomposed after 85 years:
These are front loaded horns are very easy to work with https://www.ddshorns.com/BassMid DVB 15H.pdf
You can run a nice low Qts pro driver from Precision Devices, RCF or a Beyma (see attached sim) in a 20L to 30L (depending on the Qtc you prefer) sealed box and sit just about any good quality commercial horn and compression driver on top.
Passive crossover around 500Hz to 600Hzor even up to 800Hz will work well, but the best solution by far is a decent DSP crossover / Eq which can really make this simple to build two way sing.
The DBX PA 2 DriveRack PA2 | dbx Professional Audio
is an unbelievable bargain as it sounds great, is easy to use and will teach first time DSP users a huge amount about the potential in DSP/ Eq sealed box loudspeakers.
For a Synergy / MEH, Camplo could build conical horns composed of segments approaching an exponential curve. HF can be augmented by 2 or 4 small Celestion compression drivers attached to conical sections (throats) above and below the Axi2050. Likewise, the big BMS coaxial mids 4596 and 4599 (HE) could be supplemented with enough (4-8) tweets to generate the required amount of HF output.
So instead of mounting the mid/high driver(s) at the throat - the Danley way - you use a beasty dedicated mid and put the required number of HF drivers around It. The tweets may join the mid driver >5k.
In doing so (almost) the entire vocal range would be free of XO points.
