class d Earthquake PH-10000W
class cd4070+ir2110
wave form class d cd4070+ir2110
my wave side ln-electronic.com/board/index.php?/topic/109-class-d-cd4070ir2110/
discrest class d by foodland วงจรนี้ต้นแบบมาphilip ucd เป็นแบบself osc ใช้trasistorขับ วงจรนี้การปรับvr1ำคัญมาก ปรับน้อยไปวงจรไม่osc ปรับมากไปวงจรกินกระแสมาก อุปกรณ์อาจเสียหายได้ ควรเอาหลอด100wอนุกรมไฟเข้า220vacด้วย ในขณะทดลอง
vdo YouTube
irs2092 test +-55v load4ohm vdo YouTube
ok good, but your power supply drop alot, you need to add more caps bank or use smps, i have test many time for amplifier limit, but i always do with smps + feedback, voltage drop only 1-2 max volt not more. always drop like 1v normally cause of smps cycle the power feedback 1 second. your amp maybe can go more than that with good hi power supply.
ive seen nice result from you surachit, i think you are class D fan also we need to support him, because we are now at home, cannot go anywhere because of covid-19, so all this we can do at home., hmmm igbt what running freq? surachit can you make on simple classic IC such as tl494 and sg3525AN so we can make experiment on it lol. let see if you can some for the 494 and 3525.
