What tubes for a OTL tube amp?
I built my mono blocks based on the Atmasphere M-60 about two years ago.
It's a proven circuit and I've had zero issues with them other than putting
the large toroid transformers in a separate box to lower hum.
They sound amazing and drive my super Heresies effortlessly.
Seems to be a lot of myths and misinformation going around.
If OTL is such a bad design then why is Atmasphere still thriving after many
years? I wouldn't condemn a whole topology based on one defective amp.
Just my 2 cents
Schematic?
The schematic should be here somewhere in this thread.
My old laptop died but I think I still have it in my head.
It’s based on the atma sphere M60 amp but uses ecc88 in the differential cascode and individual cathode follower DC coupled for each output tube.
I run the cascode at 2.5mA per side and the tail is also a tube based cascoded ccs.
Input stage cascode loads are 100k 0.1% precision wirewound resistors.
Yes you are right. I'm trying to decide on the best solution.
Properly done it should reduce the noise floor a little?
Thank you for the heads up. Will let you know what I come up with.
It will reduce the noise floor significantly and prevent damage from occurring to your driver tubes. If you hear a noise that's more of a sizzle than a power supply noise, that's your heather cathode insulation begging for mercy.
Aitos is a small company out of the Netherlands that has been making otl for a while. I have heard there 801 80 watt otl monoblocks with 4 large tv top cap output tubes I would love to build some but I can’t find a schematic or even figure out what the power tubes are. The 6ej7 and 6ef7 are listed as replacements for some of there products but I think they are the preamp tubes. Can anyone help me ID the power tubes or have any input about these otl amps?
Here’s some details in a YouTube video
YouTube
