The Singing Bush
point is - as long you're having enough cojones to drive that big honkiing gate , there will be no problem
SIT doesn't care of which you made those cojones
so . preceding stage with low enough impedance , and you're good
watch Papa's BAF 2015 Lecture ( link in first post) and I believe there are some graphs
...... if that's what you were asking
I know that ........ even choke loading , with carefully chosen rail and Iq , can be effective enough
though, not easy task of finding choke available everywhere , let alone output xformer
that 3A2 Iq figure was/is sooooo tempting , but pretty big bite to swallow ,going xformer route , not that much easier even decreased to 2A2
I mean an addition of impedance matching transformer at the output without changing the circuit. An autoformer should do, I'd use the 18+18V secondary of a Plitron for testing. The THD spectra clearly indicates zout being a tad high for 8 ohm. If the result sounds good then may increase supply to 90V and reduce Iq to 2.3A.
ok i've seen the lecture.
i saw at articles nutube preamp has 140ohm to 170ohm output impedance.
is that low enough to drive hockey puck sit input without any buffer?
aha , in form of patch
yup , valid idea 158%
they even had a product , intended for OTL Lovers , called Zeroformer
they sang accolades , but somehow I had impression that plain Donut was wound as autoformer , without any special materials
