Other channel has only one fet on each bank. And the readings are 6.15mV across resistors.Are these the original FETs?
Is the other channel reading about the same?
Bias pots fully CCW still, correct?
Fets came with the amp. I did not change. I only changed power supply fets to 3205 and gate resistors to 47ohms.
Pots are still ccw fully.
The FETs came with the amp from the factory? Has someone replaced them previously?
What is the DC voltage on all terminals of both of the voltage regulators?
Some one changed few and used 540 and 9540 in some places and I took them off.
Lm337
Pin1 -17.9v
Pin2 -24.35v
Pin3 -19.43v
Lm317
pin1 19.5
Pin2 20.76
Pin3 24.12
Yes shorting both bias transistors stopping pulling current and coming at 0.8amps. Also if I remove the jumper that you told me on Q11 the amp come back to normal with idle current 0.8amps.Does shorting the bias transistors collector to emitter reduce the voltage across the source resistors/idle current draw?
Yes both channels produces audio.Do both channels produce audio?
They are MPS6521 looking like never changed .Are the bias transistors the originals?
Are the resistors in the rectangle within tolerance and the values listed in the diagram?
Yes the resistors are good within the tolerance.
Do you have any LM337 regulators?
No I dont have. I only have lm317
Yes the resistors are good.Are the resistors connected to the 337 a 243 ohm and a 3.65k ohm?
I used 10k resistor and parallel to the 3.65k now amp is not pulling current and also has the output sinewave with Q11 still with jumper.Reduce the value of the 3.65k to about 2.4k (or anything close) to see if that brings the negative regulated voltage closer to 17v.
That regulator is out of tolerance. The 1.5v between the output and adjust terminals should be 1.25v.
The jumper doesn't disable the output. It switches the output stage on without a delay so you can power up with a limiter without allowing the rail caps to fully charge before it switches on.
But if I remove the jumper there is no output. It is not switching on by itself
- General Interest
- Car Audio
- Rockford 800.2
