Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
Regarding BT receiver, I have added it to my dual dam1021, and I share with the BNC input with a relay switch.
The BT receiver card supports BT 5.0 and it can output SPDIF signal. There's another receiver card which can output I2S but I chose SPDIF one because I want to share the input with BNC.
Either BNC or BT receiver signal is selected by a relay, then the signal will be passed thru the digital transformer as isolation before going into SPDIF1 of dam1021.
No, neither hardware nor firmware support for it. You would need to convert from bluetooth to spdif....
Soren,
Can you perhaps post a pinout for the J3 connector? It seems to have pins that route directly to the opto-isolators from the USB input. I.e. if I'm not mistaken this is the I2S output of the USB input? If so, I should be able to hook in the BT > I2S module I have purchased, disabling the USB IC if needed.
I'd appreciate your support on this as currently my 1541 goes unused as I discovered the wonderful world of BT lossless HD streaming with aptX.
Thanks!
Soren,
Thanks!
Sorry, but no. the dac1541 is not a DIY product, and J3 is something I was planning to use for some special testing, do NOT use J3 for anything.
You might consider selling your dac1541 and get a dam19x1, that have an extra I2S input....
