IEC Power Connector
It is always convenient to design a new build around an IEC standard power adaptor, and generally people opt for the C13/C14 type, which is similar to (but not the same as) a 'kettle cord'.
There is another polarised type with earth connector, the C5/C6, aka 'Cloverleaf' or 'Mickey Mouse' connector. It is rated to 2.5A, 7A in the US, so should be meaty enough for any amp with a 300VA power transformer, with plenty of margin for safety.
I'd like to retrofit some Quad II's with earthed power leads, and there is just insufficient room in the old voltage selector window for the C13/C14 type. Rather than hack the old chassis, I could fit a C5/C6 type with no surgery required.
To be on the safe side, I was wondering if there is there any safety reason not to do this?
I cant answer your question, but thanks for the info on this shape of IEC! I was not aware but now I do remember seeing them on stuff. Three clean hole punches to fit it rather than spending over an hour of cussing while trying to machine a decent IEC hole, nice.
An hour of cussing? I cut out a hole for the IEC connector with a cut off disc in my Dremel in under 5 minutes... Might not be perfect, but it fits and if it's not a perfect hole it doesn't matter since nobody looks at the back of the amp anyway 😛
I'm a perfectionist I guess, when I look at the back side of the thing in a crooked hole I'm bothered!
My favorite is the Neutrik PowerCON connectors. They're pretty common on theatrical lighting and pro audio equipment these days. They're a nice, reliable locking connector and they use the same D-series mounting just like their XLR connectors.
The only downside is that they can't be disconnected under load, so probably not for a mass-market consumer product, but I really like them. No need to do awful chassis work, a standard 15/16 inch chassis punch and two screw holes and you're done.
Good Thursday everyone,
This is how I solved using a 3 wire power cable. This is a standard military/industrial connector. You can find them for $10 or less on "that" auction site. I found the mating connector with power cord already attached for $1/per. Bought 25 though I will never, ever use 25.
Ray
My answer is that C13/14 cable is common and available almost everywhere. Whenever you need a power cable you can obtain it locally.
Ray
That's quite a nice solution, and those military connectors are bulletproof.
Also, because idiots keep doing it, please, please, please do not use XLR or SpeakON connectors for power applications. I see people in upper-level EE classes doing it, and it drives me insane. Aside from the obvious safety concerns, someone will inevitably plug that XLR into the input of a power amp or (worse) a console and blow it up.
The OP said he'd prefer to avoid metal work, which I can understand well, especially 'cause this inevitably would reduce the value of his classic gear. Even if the PowerCon's round body would fit into the given hole, which I'm not too sure of, he'd have to drill two additional 3 mm holes for the mounting screws.
Best regards!
My father brought back from WWII a couple of German field telephones. He used standard US two conductor power plugs and jacks to connect the telephone wires together. Years later as children we found them in a closet and first thing we did was plug them into a wall outlet. When the smoke cleared we ran to dad to find out what was wrong with them...
Wow, that's a staggeringly bad idea "let's use a low level signal connector for a high voltage source capable of delivering high current"
