This is the coolest vac I’ve ever bought, built by flex power tools in Hungary(if not mistaken)
Plug your saw, sander, whatever makes fine dust into its on board outlet and comes on automatic when you hit the tool switch/stays on 20 seconds after shutting tool off!
I was a little worried about the 15 amp saw but as long as you don’t bind the saw up (like cutting wedges you have to go slower) it doesn’t blow the breaker.
I think it actually might get the proverbial golf ball through the garden hose! 😀
I don't have a vacuum fetish, but I am finding this thread very and oddly entertaining, and it seems to have legs!
This image may tick all your boxes!I am finding this thread very and oddly entertaining, and it seems to have legs!
I guess this post demonstrates expectation bias that this thread does indeed have legs!
My Die Zone blackhole V.end model is better than yours Dyson V6.
One trade off though...you must vaccum in the dark.
I can't run my table saw and shop vac at the same time, they tripped the breaker when I tried it. I plug the hose into the saw, and run it for a few seconds every few cuts to clear out the saw.
Most be a big saw. I always run my table saw and vacuum together on a single circuit and cord. Never a problem - even tho I expected it to be.
What you need, Cal, is a motorised vacuum cleaner! 😉My right side has had a dislocated shoulder, a torn bicep and a 'funny' thumb all in the last year.
Ha ha! 😀
Well I have ridden the big vacs in hotel ballrooms. I could sure knock over a lot of furniture with that.
Would that have sufficient current carrying capacity for this giant vac?Could try running a good 12awg ext cord to a different circuit for the vac?
Is this Shaq's latest street mobile or is it his ride on vacuum cleaner? 😕...might need Shaq to come over n’vac yer shack! 😀
Ha ha! 😀
That's not a vac, that's a zamboni!
It is German and quite expensive:This is the coolest vac I’ve ever bought, built by flex power tools in Hungary(if not mistaken)
FLEX Power Tools
I learned there are at least three categories:
- home appliances
- hotel vacuum cleaners (they use it 7x24x365)
- industrial tools, used at construction sites, they used to suck dust, wood chips, debris, water, mud, whatever.
Well I won’t argue about it being expensive, but it is indeed of Hungarian manufacture (even though it may be a German company)
I think they are trying to get a foot in the door in the US market because I got it for $299 (less than half retail)
I’d never heard of the brand and research didn’t show much except two happy customers......took the chance and glad I’m did, it’s a quality piece.
- Member Areas
- The Lounge
- Vacuum cleaners
