Amp Camp Amp - ACA
But i see damping is 10 and when making bridge it will be 5 and i think it is a bit low.My FR speakers are 86dB 4 inch and i think it needs more power to fill the room
It is more about the driver & box than the size. I have 2 stereo diyA kits and one of the earlier 5w ones.
Either drive my 87ish dB WAWs (with a pssive XO) fine, a pair bridged have tow high an output impedance (lets lose the term damping), than optimal (bass gets wooly), i haven’t tried a pair in parallel, which should halve the output impedance (and the direction you would wan tot go with 4Ω speakers).
What are your FR/box?
dave
bridged ACA with 5670 SRPP tube stage...
  • video-1576112482.mp4
    3.2 MB
i never had any of these issues in all of my builds...
The reason there's no startup fart/switch off thump in balanced mode is the fact that speakers' outputs are not referenced to the ground - no charge up/discharge of the capacitors through the speakers, and into the ground.
There's no potential difference between two ACA PCB's / two outputs (minuses) at any point in time during turn on/ turn off - this is a characteristic of ALL ACA's operated in balanced mode.
So.... nothing special about your builds, it seems... but don't let a bit of technical knowledge/truth discourage you from believing you do indeed have special builds.
i have built more than 100 boards, most of it single ended ACA,
an about a few bridged amps, never had any problem you mentioned...
what i know is that the smps psu we used have a soft start feature...
and they were of the cheap variety....an NTC in series with the line with a cold resistance of about 10 ohms is good to use here..
ACA Parallel mono configuration, close amp matching needed?
according to the ACA V1.6 Operation modes (link below) the parallel mono configuration would fit my needs the best with more power into 4 ohms and less distorsion. However, I understand that parallel mono may require the amplifiers to be closely matched (e.g. gain and DC offset) to work well. Close matching does not seem to be required when the amp use current drive.
Can anyone please explain current drive in the context of the ACA?
Does the ACA 1.6 use current drive or do the amps need to be closely match using the parallel mono configuration?
https://cdn.shopify.com/s/files/1/1006/5046/files/ACA_Monoblock_Operation_RevA.pdf
M
The ACA always has zero DC offset by default... it is AC coupled. So no problem there.
Amplifiers with high damping factor/low output impedance do require good gain matching and also some form of current sharing (such as low value series output resistors) for parallel operation.
As far as I am aware, the ACA's low damping factor/high output impedance render such precautions as unnecessary.
The ACA would be classed as voltage drive, however the high output impedance means that the output voltage is subject to being altered significantly by the impedance of the connected load.
Next step power amplifier after ACA
say that I would like to get into to the slightly deeper section of the pool and build a discrete power amplifier that would be step up from the ACA. What would you suggest as the next step after the ACA?
/M
