I'm back I see what I did wrong on the function generator I was connecting the GND so after I disconnected then is working normally see image is that correct?
Welcome Juan sir
Thanks a lot Mr Mile
regards
hey bro I was checking your layout and there is a missing connection see image
Welcome Juan sir
hi I was away for a while doing practice of drilling on aluminum and tapping
thanks eagle-eyed
Still busy with these .. for 100 vdc + / -
A33 with 100-0-100 VDC ? With 2 powers positive and 2 powers negative? He gona burn certanly.
no man that is too much for 3 pairs just 45V to 65V DC +/- rails
thanks eagle-eyed
6 years learning this this is similar to the one you are doing an example
Im going to use 100 vdc + / - with 7 pairs of C5200 ang A1943 ...
thanks eagle-eyed
I think that each power out transistor must be have it's own base stopper resistor.
Better ask Mr. Mile.
Hi!PSU and Stereo Protect for A14, A33, A40...
Do you have any PCB for this PSU?
Hvala lijepo!
agree they should have base stopper resistors
Nice work.
hi mr mile...i complet fh11 with3pair irf640/9640 and its very good...
now i want made apex ax17 and i have queschen....
can i use 3pair 2n3055/mj2955 with 50 volt suplly...?
can i replace 1837/4793 driver's with tip41c/tip42c or bdw93/bdw94 for more power when i use 2pair c5200/a1943 in out put?
what maximum suplly for apex ax17?
apexax17 is better or ax20?
Go to A33 or A23, A40...
i'm desingn ax17 with 2pair out put and 1pair...and this projrct give many time as me....i most finish this ax17 then i go for a23/a33/a40...ans sr200 with sanken..but step by step....my pcb for ax17 is very nice when i finished it send pic for you...
now can i replace 2sc4793/2sa1837 with tip41/tip42 ?
this is my pcb driller.
there is a sliding bearing have, in the middle of the plywood, to slide top and bottom.
nice work and good jig, post plans or link
hi mr Mile
do you have PCB for PSU60?
- 100W Ultimate Fidelity Amplifier
