Hello All,
I have some 3Fe25 that i will use as simple PC speakers, Daily radio and Youtube.
The design will look like this. The horn / tranmission line is a constant Area of 40cm2 for about 100cm.
What is the proper way to simulate this? I did some test with Hornsesp but im not sure i do it correctly.
It will be 3d printed so the goal is to have it within 200x200x200 mm. Wallthickness is 6mm, but 8mm where the driver gets mounted.
The top and bottom will be 12mm MDF or Plywood with a milled slot to make it air tight when i glue it together with the 3d printed part.
Seems needlessly complex for a desktop speaker, but maybe that's just me?
jeff
You are probably right, but the hands on build time will probably be less than an hour. I have a lot of time on the road with my computer which gives me the time to over do it i suppose.
I will print a template for a hand router so the milling will only take some minutes when all is printed and done.
So far it's just a concept so i'm pretty open for ideas!
The driver should be offset from the end of the line to cancel the 1st unwanted harmonic. This means less damping needed and more bass.
Look at the Woden Baby Labs which are topologically similar, but have a taper to reduce the needed length.
Woden Design 3" Box Designs, BabyLabs & more
dave
dave
YouTuber Hexibase 3d printed a similar enclosure Here.
Yes i saw that, and since i have a printer and the speakers avaliable i started doing my own. Question now is how to optimize them since my Hornresp knowledge is limited.
Now i'm playing around thinking how they would look like on a desk with some legs.
Ideas are welcome! I will share the printer files if anyone is interested
Neat. I will do some reading on how to offset the driver in hornresp. I am limited to about 5 liter in horn volume.The driver should be offset from the end of the line to cancel the 1st unwanted harmonic. This means less damping needed and more bass.
dave
Which will offset the extra damping required due to all those lovely round corners allowing excessive mids/HF to exit the pipe, comb filtering with the driver's output.
GM
I like your original concept better. You just need to model the line again.
jeff
I could make the insides with irregular pyramids or any other shapes if that would help?Which will offset the extra damping required due to all those lovely round corners allowing excessive mids/HF to exit the pipe, comb filtering with the driver's output.
GM
All you need do is have sharp corners/u-turns instead of nicely rounded, like Fostex or similar designs. If you want the exterior rounded, then make it a separate shell and fill the gaps with something massive such as sand as it ideally needs to be well damped/heavy.
Also, mouth should terminate on the baffle with the driver.
GM
GM
GM
The exterior will just be a result of the interior in this case. The aesthetic can be solved later. The reason for sharp corners as you say, if I understand correctly, is so the high and mid frequencys from the back of the speaker don't bounce straight out the mouth of the horn?
About the mouth of the horn to end on the same baffle as the driver, are you referring to a BLH? How do you add where the mouth is positioned relative to the driver in hornresp?
A little of thta maybe, but primarily the “square” bends create an expansion in the line which is a low pass filter.
dave
dave
For a BLH, is that something that is possible to simulate in Hornresp?
Also, is it the same for a TL?
It can certainly be done in MJK MathCad.
Each bend looks like this when you unfold it:
dave
- Full Range
- Desktop TL / BLH with 3Fe25
