Hi Chris
I generally agree with your advice about the 25V POWERAMP LM1875 PSU, but my question was about the quality of the 15V PREAMP PSU-addition shown at LM1875_20W_diy_haoDIY.
Is that PSU-addition (used for powering a preamp) ok for hifi?
Ahh...sorry....i overread this.
generally a voltage stabilizer with zener diode is the simplest way to reduce 25V-15V. resistor and zender diode are"noisy" . so for a pre amp its important to use a very low noise psu. usage of a linear regulator + 7815 / -7915 minimum setup.
its needed to know how much current/power your preamp needs and with some margin you can search for a low noise/ultra low noise regulator (TPS7A4700)which can handle your current and the peaks.
chris
Yes, forget about that pre amp supply in the link and as mentioned above use a 781x / 791x depending on what output voltage you are after. Better still is the 317 / 337.
Have a look at ESP P05 (all versions). You can take off DC from the 25V rails from the amplifier supply so you don't need the rectifier diodes.
Erm.. Actually one does not require a Pre amp.
This being well into the 21st century, most sources output a directly usable voltage.
That can one feed directly into a power amp .
A simple Dact type stepped attenuator serves well, being more transparent than even the best silly priced preamps.
Despite their maker claims.
Try it ? It's a very simple experiment.
IF there are impedance issues (flat sounds) a Passdiy.com B1 buffer $50$.. Ably does the matching task.
I had the feeling, there were more to it than just 2 zener-diodes.
Think I'll go for Rabbitz's advice with the ESP P05.
For reference the 15V linear PSU is not for a preamp but for powering an active crossover for the chipamps.
Any suggestions for a good sounding diy 2-way opamp version?
Crossover? suggest a ...Passive... line level Crossover which uses NO op amps, No power supply
Because of that it's simple and V inexpensive to experiment with and to build.
Calculator is here;
TLS.org | Passive Line-Level Crossover
Imo even that is overkill / inappropriate given the size/range/quality of speakers an 1875 amp chip can successfully drive.
Small, and ironically as there are few made: High 80's low 90's db efficient ~4" full rangers).
Just saying .
Calculator is here;
Just saying .
Have a look at Rod Elliott's. Boards are available and with the low AU$ reasonably priced.
ESP Projects Pages - DIY Audio and Electronics
Yesss... but I balked at buying... as the cost of Postage, even for a 'Quite Small' PCB is a flat 14U$. Offputting to my sensibilities.
My currently 'Iffy' Canada Post charged 7$ Cdn (5 U$)to air parcel under 100 gms to Aus .. I sent 6 postcard sized pcbs there .. under 1/2 the weight limit..
Hi
any recommendation for a size of amp housing or heat sink size for this amp?
As i rad at dunk02 thread his housing was very tight
i will not install a preamp section. no knob
thx
chris
hi
iam looking at this thread - post 56 + page 2 - and "estimating" the dimensions:
https://www.diyaudio.com/forums/chip-amps/338645-lm1875-amp-layout-6.html#post5828362
the LM1875 is about 18mm (Datasheet last pages) high and 20mm extra is the high of the aluminium plate what dunk02 use for mounting on the heatsink. the pcb is 46mm long and if i look at the pic its about 4-5X the lenght
so the heatsink is about 40 x 250mm for both channels.
chris
Hi
thx
chris
Heatsink needs to be 1.5°C/W minimum for 2 channels (ref ESP).
I use a Galaxy 288 2U (GX288) for my 3886 builds so would also suit this amp. Around EUR28 plus shipping from Modushop. Might be able to squeeze in GX283 but that's about the same price.
Galaxy Maggiorato GX288 230 x 280 mm
These cases also available at the diyaudio store.
Here's a pic of the Neurochrome 3886DR which has larger PCB and heatsink but gives you an idea. The transformer is a 160VA.
The last PCB's I got from Canada were US$11 shipping.
I'm not trying to justify Rod's price but it is postage and handling which includes a padded envelope and his time. There is a US$7 option for under 50g which would cover a 75mm x 150mm PCB.
Thanks Rabbitz !
good to know that a 1,5C/W is suficient for both ....but i still not sure to use the case (cheap) like you propose with "internal" heatsink or use a small case with heatsink on both sides. ..anyway i have to look for the transformer size and CRC etc..for "designing"
1,5C/W is not expensiv:
%product-title% kaufen
thx
chris
I like how you set up your amplifier. I think I´ll opt for the same configuration.
I have been using my amp for a month alternating headphones and monitors. I have both LM1875 attached to a single heatsink (10x6x2cms) and the temperature remains quite low at all times. Moreover, I think that the 337/317 of the PSU get hotter than the amplifier.
Just remember that the length of the heat sink in the spec is the vertical height when placed inside a case.
The width and height shown in the spec is the cross section and the length is how long it is when cut. So for a 2U case you need a length around 75mm.
To give you an idea the heat sink in the picture in my previous post is a Conrad MF15-75 with the length at 75mm which goes from the bottom of the case towards the top.
Conrad Heatsinks - Products
I'm surprised you are using a regulated power supply as I just use a standard linear supply. They will get hot as I think the 337/317 are good for up to 1.5A unless used with a bypass transistor (never built one).
Why a regulated PSU? Well, I think that as a headphones amplifier or monitors amplifier, you don't need much more than 1.5 Amp either: It´s an LM1875 ... and IMO this amplifier is perfect for these things. If you need more power or you want to move bigger speakers you have other options within the Gain Clones family.
A PSU based on 337/317 is cheap and simple to get already assembled and allows you to play with the output voltage. In my case I have been altering the PSU voltage from +/-14Vdc to+/-19Vdc which has allowed me to check the performance of the amplifier.
Other reason is that a regulated PSU is silent enough so you can use headphones with high sensitivity.
Daniel in the thread "Beginner's Chip Amplifier, HiFi LM1875, The Amplifier Board" mentions the power of the transformer. If I remember correctly, talk about 1Amp
I have some measure done with headphones and I think it barely reaches 0.5 amps of maximum consumption per B rail with both channels connected (I have to check my notes).
This amplifier is so simple and so economical that I am simply dedicating myself to experiment and I recognize that it has been quite entertaining.
The only problem that I have encountered with the use of headphones iswith very sensitive headphones. You can hear the floor noise from a certain volume. The solution that I have found (without touching the gain) is to add a series resistance (50 to 100 Ohm) to the output.
AAAhhh. yes you are right...this heat sink are good for testing on the bench. but if it should in the case i have a "tower" of 100mm
your proposal is really nice thanks! MF15-75!
do you have a proposal for a nice small PCB or ready PSU board for this small amp. i have some board and can do point to point but for the final solution.
chris
There are quite a few power supply boards on ebay and one is shown in the link in post #5. You don't need anything fancy but I make my own as I just Dremel the tracks as required on a blank PCB.
The pic shows the power supply I will be using on my build for when I finally receive the amp kit.
240V in through a IEC socket with fuse holder (1A slow blow.... 2A for 115V) > 6A switch for active wire only > 50VA 18-0-18 transformer > 35A bridge rectifier (10A would do) > power supply board with ground connected to mains earth > 3 pin XLR connector > umbilical cord to power amp with all wiring 7.5A.
The power supply board has the 2 inputs (+/-) from the bridge rectifier followed by two 4700uF 50V capacitors. Fuses (1.6A fast blow) are on each rail which then go to the output supply wiring to the XLR. The transformer centre tap is connected to the PCB at the output end with a machine screw and is wired to the earth connection. The ground is then connected to the output wiring XLR. There are 2 resistors on the output side of the board and these are for 2 LEDs with one for each rail. One is for the power board so I know power is on and the other for the front panel LED. All connections are via 6.4mm spades.
Tested today with a LM4780 module and no load gave me 28VDC rails and fluctuated between 25VDC to 27VDC under load. Nominal was around 26VDC and fell below 25VDC a few times during heavy passages.
Installed in a small plastic Hammond instrument case and nice not having to machine metal for a change.
- Chip Amps
- eBay mono LM1875 kit
