New Markaudio Drivers
Here’s a little love, 12pw’s and a ribbon tweet, second order passive 8khz hi pass on ribbon...but we digress...
Hi all,
is there a Sea Stack MLTL for Alpair 7ms? I would much appreciate it. Thank you
Yes and no. If you'll forgive the expression. I can do one, in fact I have the dimensions saved -it just needs drawing up. The reason I haven't published it is simply because it won't go much lower than, say, the compact Okapi MLTL I did for the 7MS, and has higher driver excursion (there's a limit to how much you can realistically squeeze out of a fairly small unit). If you want me to put it out, I will, I simply note that is the price and that in this case, I prefer the smaller enclosure.
OK - thanks for additional explanations of benefits of Okapi. My thinking was exactly to see if Sea Stack will go lower or not
