A sign that the A12pw does not get enuff love. I really like this driver (listening to the big MTMs with these and A7)
dave
dave
Not yet, but i have drivers, FHXL & FH3 to compare them FR. And A WAW i plan to try A7ms in.
dave
dave
dave
Great stuff Dave, I really look forward to hearing your thoughts.
If there is, I wouldn't expect it for a good while, the Pluvia 11 is still quite a new driver. The 7HD uses most of the guts of the old 7.3 with some mods. and a new basket; the Pluvia 11 was a new size unit so already incorporated some of the design features of that older generation of Alpairs.
Looks like there is an A7ms “SeaStack), but it does not yet have a name or has Scott QCed it.
dave
dave
Hi all,
is there a Sea Stack MLTL for Alpair 7ms? I would much appreciate it. Thank you
Yes and no. If you'll forgive the expression. I can do one, in fact I have the dimensions saved -it just needs drawing up. The reason I haven't published it is simply because it won't go much lower than, say, the compact Okapi MLTL I did for the 7MS, and has higher driver excursion (there's a limit to how much you can realistically squeeze out of a fairly small unit). If you want me to put it out, I will, I simply note that is the price and that in this case, I prefer the smaller enclosure.
dave
Oops. the design i was looking at was the early SeaStack drawing.
dave
OK - thanks for additional explanations of benefits of Okapi. My thinking was exactly to see if Sea Stack will go lower or not
If i may ask, below plans are similar in dimensions. In terms of performance - what is main difference (if any)?
http://wodendesign.com/downloads/A7ms-compact-MLTL-060918.pdf
vs.
Okapi 7MS
vs.
Okapi 7MS
Broadly. https://www.diyaudio.com/forums/ful...-fostex-tb-dayton-seas-etc-2.html#post5554175
I'd forgotten that one. It's not quite as refined as Okapi (or the pensil) so those would be my pick of the MLTLs that I've done for the 7MS.
Thank you!
- Full Range
- New Markaudio Drivers
