None of that does anything to convince me a $400 pot is a good buy. Nor a $250-300 pot But I don't want to derail this thread, so back to watching.
Or for the not so adventurous:
DACT Type SMD Stepped Attenuator 21 step volume control pot D Shape Shaft | eBay
DACT Type 21 Stepped Attenuator / Volume Control (Hi Fi Grade) * D shape Shaft * | eBay
Can also order them with different shafts.
Using them in a B1 buffer and a 12AH7 preamp.
Beats every ALPS, no contest.
whether you can feel the steps while turning the axis shaft?
Yes, I've tried ones like those at that price, and they were a distinct improvement at a WAY affordable price.
I mean, do you feel steps under your fingers....
Mine, which is pretty much the same, has distinct steps but quite soft and smooth operating. There's no real effort to turn the volume. For me it's quite nice.
Yes, most definitely.
Exactly as Carlp described it.
Yes slightly, but you can hear the steps distinctly also.
These are much better pots than the price would imply.
You can buy spares for future use, and save shipping too.
Thank you very much.
This is important for me because my audio system has separate volume regulators: one for the left and the second one for the right channels. If I turn both with the same number of clicks I am sure I have proper balance...
b.....Al knob (4mm shaft , so that causing troubles with knob choice ).....
will change vol button for something nicer , as soon I find where I left small bag of 4 to 6 shaft adapters (sleeve, practically)
I've made plastic 4-to-6mm sleeve ( where is full bag of these?) and that allowed to mount old school Zen Amount button
and black allen bolts as final touch
perfect scratch -resistant finish ..... wherever you scratch it , it's already scratched
These female chassis mount jack connectors…..some look very fancy from outside with an "alu-face" and a kind of lock mechanism. But is the inside of these connectors the usual "plastic"? …..are there quality difference among them? …..you don't extreme expensive jack connectors like you see with RCA?
I said it was quick'n'dirt build
I would like better can connector (mostly better mechanically than with contact) but forgot to order in time
output GND isolation from case was a must , so plastic was first and easiest choice ......
The only experience I have with these jack connectors is from Starving Student II where a PCB mount connector is used. Seems to do the job. Next will be whammy where I have the kit. Here is also included a connector. I wonder if it is worth upgrading to one of the more fancy connectors. What I can say is that the AudioQuest converter from jack to mini-jack is "super duper" and made in one piece and silvered. It is many classes better than the other converters I have.
over engineering again ?
many things and details are worth thinking of , but not exactly worth enough to waste time typing about
if changing to some other option is simply making you happier , that's good enough reason , in my book
- Pictures of your diy Pass amplifier
