Ok, i will try
This is going to be ordinary TPC and with lover PM and GM, not my amp any more.
Your OITPC is unknown to me so it's up to you to provide Thimios a cap/resistor combo to increase the PM/GM for testing.
I'm out.
BR, Toni
I'm out.
BR, Toni
Let's see how this measured when not oscillate.
Distortion value is close enough to my sound card loop THD.
It is late for edit.Let's see how this measured when not oscillate.
Fist photo=2.83v/8R
Second >> =7v/8R
Thrd >> =13v/8R
Fist photo=2.83v/8R
Second >> =7v/8R
Thrd >> =13v/8R
How you solved oscillation problem?
I haven't sometimes not oscillate.
Just now i try using +/-35v and up to now i can, :see any oscillation.....but now i use input signal from a function generator.
Still +/-15 is ok.
Still +/-15 is ok.
+/-35v
That looks good.
I think so too!
Sinusoidal test.
The 47pf is under the board🙂
There also, 1nf from base to gnd at the cascode but i will try to remove as no improvement when testing using +/-50v
I think so too!
Sinusoidal test.
47pF, which one?
FFT analyze
+/-35v
idle=130mA
First 1,2,2,4 the sound card loop test.
+/-35v
idle=130mA
Thank you Thimios for all those measurements.
It's quite close to the simulated values.
Damir
Thanks Damir for this excellent amplifier.
Bravo!
Please feel free to ask any other measurement-test. 🙂
P.S let me to say thanks to a very good friend from Belgium, who donate me the Laterals.
Thanks xxxx🙂
Bravo!
What about listening test, I think you said you don't have good enough loudspeakers?
Unfortunately not... and i have one chanel only, up to now.What about listening test, I think you said you don't have good enough loudspeakers?
This was my last piece of duble side photoresist pcb🙁
Listening to one chanel isn't a good practice but those measurements say all the story about what expected. 😎
YouTube
Hi Thimios,
is the problem of the oscillation solved now and what was the reason for that?
I manage to run this at +/-35v and everything is under control.
May be Damir will find the way to be stable at +/-50v latter. 😉
- Lateral CFA 120W - BSA
