Lateral CFA 120W - BSA
Ok. Here is the scope at the output, no load, no input signal.
Most of the time is 21.7Mhz.
Yes, I used it in my Simpelstark amplifier with very good results.
See the schematic of one of my successful ODNF implementations attached.
I left the reference numbers as is, left from my complete schematic - never mind.
OITPC combine with ODNF? Interesting.
In all topology that use OITPC, I found at low level the harmonic level is almost monotonic, but at high level depend on topology. I think, OITPC only reduce high order distortion at low level.
I think in amplifier, output stage is highest distortion source. So, ODNF is one solution to reduce output stage distortion. But I do not like use op-amp for ODNF. I think, we can make discrete op-amp for ODNF easily, because it do not need DC precision and very low noise.
I hope we can make class AB amplifier with harmonic profile like class A. But we need new thread for this.
