Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
My gut feeling tells me that sharper shapes used for diffraction work better up to higher frequencies in achieving wide dispersion but smoother ones have less unwanted side effects (like uneven frequency resonse and horn honk).
Charles
Apart from the shape of the slot (sharp/smooth edged or bubble-like) it's the location of the slot (along the z-axis) that determines its impact on the response.
Nearly all JBL horns, from the bi-radial days up to now, are a combination of a slot near the throat and 'bubbles' towards the mouth, in the vertical, horizontal or both walls. The M2 waveguide can be considered as the culmination of decades of R&D.
I assume the further back the slot is, the better in terms of resonances etc, right ?
In general yes, but the physics of diffraction slots is very complicated.
I have yet to find research that's all encompassing in this respect.
Most research is done using BEM/FEM, because as far as I know, there is no such thing as a unified mathematical theory of diffraction slots.
Yup, horn is pth-1010hf
One of JBL's most elegant horns:
It looks different, but (basically) the same horn was used for the DMS-1.
In combination with modern loudspeaker management, this is still a sota studio monitor.
Is it ok to paint it to make it look more presentable?
Sure! Though according to Boeing it needs a < 400 micro-inches finish for best performance, i.e. essentially hydraulically smooth or in the vernacular, 'smooth as a baby girl's bottom' 😉.
Some of the molded horns I've seen were smooth enough to only need a good wax job with the most aerodynamic DIY paint jobs I've seen were either dipped or had a lot of hours of [meticulous] hand rubbing.
GM
Or use NEXTEL.
'NEXTEL' was originally developed by 3M Company in the USA following a request from NASA for a special coating for use on the interior surfaces in the Space Shuttle.
