TPA3255 - all about DIY, Discussion, Design etc
Thanks for the suggestions.
I can already see a few likely candidates on ebay, cheap too!
I should be able to get 1000w for the same cost as two more LRS-350-48s
And as cacao ambiance mentions a quick google brings up tips on how to hack them to work. Seems people are using them as battery chargers.
I assume they are pretty clean output because of their intended use in servers?
Hi, mates. It is me again from Ukraine. Just got back my tpa3255 from repair. It cost me 8$chip and extra 10$ for work, i wad lucky to find local guy who did it work again. He told me the most possible reason could be static thunder during switching due non isolated switch from the supply rails. He advised me first touch antenna metal before touch the item. Keep in mind this device engineering fault . He also found one channel was not damaged but due one of them was fault / master the second chanel wouldn't start.
Anyway I am listening amp now and it delivering rather tight sound level even with 19V/7 A power supply adaptor.
Just for your reference I now having double chip tpa3116 board, tda7499 and this tpa3255. They are listed in increasing order of terms of sound quality for my personal preferences. Without doubt tpa3255 even in my simple design board YIAMA deliver pleasant sounds. I also got MARANTZ SR6400 for a while to compare 110w/8hom 0,003%distortion and found tpa3255 almost equal in direct mode with no heating up like this 15 kg monster. And yes I would recommend DAC I am using now :AIYIMA HIFI аудио ES9028Q2M SA9023 USB worth 20$ and you will hear the difference after pcm2704 for sure. Good stuff with no drivers for Windows xp, android, even tv box xmini96 got it vis usb p- audible difference for youtube comparing with buildin dac.
Here are links for items
536,03 грн. 29%СКИДКА | AIYIMA HIFI аудио ES9028Q2M SA9023 USB декодер DAC плата внешняя звуковая карта Поддержка 24Bit 96 K для усилителя
AliExpress
277,74 грн. | CIRMECH цифровой усилитель аудио доска TDA7498 Мощность Аудио Amp 2,0 Усилители класса D стереофонический усилитель HiFi DC12-36V 2*100 W
... I assume they are pretty clean output because of their intended use in servers? ...
yea. I’ve not noticed any noise when powering a power amp from it.
i use it instead of a battery. so i have a dc-dc boost converter already with amp to give it best voltage it needs. the 48v for tpa3255.
i would not get a bunch of those server power supply's and try and wire them up to get 48v. It’s a risky hack. hmm is a sure 500w or unknown 1500w dc-dc boost converter converter and a cheap server power supply cheaper in total, than the LRS-350-48?
Note that these server power supply's tend/are to be 12v high current.
I have got new/other unused meanwell 24v, few hundred watt power supply cheap cus there where left over from a job and the guy was selling the spears cheap on ebay. I think they where used for leds but they where a plain constance voltage and Constant Current power supply. not used it much if at all...? i forget. seams fine. was new in box.
one server power supply i got was broken. the ferrite was snapped in pieces inside. opened it up and took photo. the ebay seller refunded me then. before i wasnt sure if it was something i had done wrong. not wired it up right maybe... but that lose bit inside was not right. if it doubt open it up and see if there fault. get a refund 🙂.
on my good dps power supply, I soldered thick flexible earth cable we got from skip years ago. with a xt90 power plug on end of cable.
theres photos on http://social.aross.me/
scroll back a year or two. #mytechproject i think
AliExpress
There is no links!😉
There is no links!😉
Sorry, this is the links list of my items
AliExpress
163,87 грн. | 1 шт./лот TPA3255 чип 3255 чип TPA3255DDVR HTSSOP44 TPA3255D2DDVR микросхема новый оригинальный
AliExpress
AliExpress
136,09 грн. 36%СКИДКА | TPA3116 2*100 W Bluetooth цифровой Мощность усилитель доска двухканальный цифровой аудио платы модуля усилителя Super Bass Ampl
AliExpress
1 548,36 грн. 18%СКИДКА | AIYIMA TPA3255 Bluetooth усилитель Аудио Усилитель мощности доска Класс D 2,0 канал 300 Вт * 2
AliExpress
replaced the original 68uf nichicon capacitor that came with the amplifier with a 4700uf 63v Nichicon muse. this is the best i could procure. relocated a cap and gave the cap extra long legs. and hot glued in place.
The sound output has indeed improved. the bass sound less muddy. overall output is good
Will try to do similar mods and let you know. My board iyama looks similar. Got 10000 mkF 63v Rybicon
