MOSFET Amplifier IRFP240/IRFP9240
Bias setting is very sensitive, you can use 220R pot in series with resistor instead 1k.
Mile, my problem isn't the trimmer sensivity but the high bias setting by me.Difficult setting due to resistors absence.
Finally i have add a 18R/5W resistor in series with the positive supply and i measure the voltage to calculate the current.
After bias setting this must be shorted.
In any case you will be surprise when i post results
I was checking my layout to the schematic and I was missing the connection between V+ and the 1k2 and 4007. I have added it here. These should be correct. now. Sorry for any inconvenience.
Terry this pcb must be more robust especially into the mosfet area, use bigger (fat) traces.
My modification.
This amplifier have high THD for my taste, but have good harmonic profile. Slew rate is high enough.
Bimo, because i know nothing about simulation can you inform me what are the alternative parts?
Thanks all of you for your interesting!
PS. who can answer what is the absolutely maximum bias setting that is safe?
My modification using bias servo, so it safe to set bias current high, but I recommended bias current is 150mA for compromise good THD and efficiency.
Maybe you can ask Prasi to make PCB layout.
Hi Thimios,
I did enlarge the power and output traces. I didn't think the gate needed more. I will try to populate tomorrow and give mine a go. I plan to use an ammeter on V+ to set the bias. Wish me luck.
Blessings, Terry
high bias test
Power Supply=+/-50v
offset about 7mV
Idle current about 280mA OR More... be carefull,not safe!
Input current=3mA
VAS current=4mA
VAS transistor=2sc3902.
bias 140mA
BIAS=140mA.
Testing this on a real 3way speaker
In this test a real 3 way speaker used as load.
Bias=50mA
I must run this last test again because another, different divider, was used.
I hope that all these will be useful....
I would like to dedicate this work to a very good friend from Belgium who made me an incredible donation
He does not want his name to be published.
