Full Range Speaker Photo Gallery
Joined 2016
Not to mention the humidity levels that are crazy high in Southeast Asia!
So hard to keep molds away from anything made of wood.
Nice old school style boxes.
Enjoy!
wood worm is up there next to humidity. we lay in bed at night an listen to the critters munching away at the wooden headboard behind our heads! one morning I will wake in the middle of a pile of saw dust
Karlsonator 6 with Dayton Audio ps180 drivers.
These boxes are LOUD. They throw a soundstage out and up.
They also do great job taming the ragged highs of the wizzered drivers. I don’t know why that happens but I like it a lot.
Thanks to all the experts here willing to share their designs.
that's termites, but if you treat the wood with solignum then varnish with polyurethane or any other varnish no problem, termites do not likes chemicals :rolleyes:
Karlsonator 6 with Dayton Audio ps180 drivers. View attachment 758868 View attachment 758869
Congrats very nice speakers, what is the principles of Karisonator enclosure?
robmusk,
Nice set of speakers you got there, and thanks for sharing your impressions.
There are several threads that describe the Karlsonator principle. This one is a good place to start:
advantages of karlsonator
I first tried these drivers on an open baffle crossed to a woofer, where they sounded terrible. Like needles head on and buried under a blanket everywhere else. The k-slot works wonders to disperse the treble.
There are lots of threads on other sites with disparaging comments about the negative effects of the slot on the response. So they might not be HiFi, but I don't care since they sound so engaging. I've made a few boxes and baffles for full range drivers before but these are the first I felt I needed to comment on. Music fairly leaps out of them.
Very interested in your take on that driver in the FHXL. What amp? Corner loading them?
dave
Amp is a Denon POA-2800 plenty of power too much for these. Not corner loaded, I just was in a hurry to try them out they wound up next to my main speakers. The side walls not in the picture, are bout 5 foot away from the speaker, and its about 5 foot to the back wall. They are very shouty, I am currently reading about baffle step correction.
Do you think placement in the room will help with this much?
Any advice appreciated.
Thank you Dave
So far this has been a very fun build(winter project), planning to veneer them.
Yeah, just finished wiping down some wood furniture, cabinets with hydrogen peroxide, misting it on bookshelves full of books, knickknacks, etc., basically everything that collects dust since I don't have central heat/AC to keep humidity low.
You got me curious since Hotlanta is Mold City and a bit surprised it's pretty much as bad as Taiwan, though numbers wise neither of us can compete with the Philippines, but wonder if it feels much different; I mean once you're coated with smog/pollen/dust laden sweat, dizzy, etc., how much worse can it be?
GM
here's an update for the p610 clone build. simulated wood grain finish.
the steps to this finish is as follow
1)sanding and filling the readily visible imperfections
2)applying epoxy primer
3)filling and sanding
4)another coat of epoxy primer
5) sanding to remove bumps
6) applying pink color quick dry enamel
7) staining with diy mixture of color tint and pain thinner
last step(havent done this yet) is of course to put a top coat. which in my case is satin finish poly.
