Installing and using LTspice IV (now including LTXVII), From beginner to advanced
This 'ac mode' and 'trans mode' is confusing.
A .ac is a frequency domain simulation, you look at something versus frequency on the X-axis. Like a spectrum analyzer.
A .tran is a time domain simulation, you look at something versus time on the X-axis. Like a scope.
What you do with .ac gives you the Zout versus frequency, and I guess that's what you want. Using a .trans gives you the Zout for one frequency only*, but you can see the 'shape' of the Zout related to the shape of the load current. Not sure whether that is useful.
*unless you use a multi-frequency or FM source
Jan
yes thanks. That’s what I thought, but I was getting some misleading AC mode readings without a time reference. I put a current source on the mosfet that was being used to test a voltage source per Molly’s suggestion. So I loaded the mosfet with a 3k resistor for 100mA at 300V and put a current source of 100mA sine wave between the gate and source. But the simulation gets stopped with an error.
I think many here who want to help are not looking forward to chase something or other up though the many 100,000's of posts here, only to hear the poster tell them: no it's not that one ...
We also have lives. Most of us, anyway ;-)
Also, a posting 'the simulation gets stopped with an error' is unlikely to lead to a specific reply/tip. Its like telling your doctor 'I don't feel well' and expect a detailed, to-the-point medication prescription.
Jan
Sorry Jan. It seems like a timestep error. It appears the V/I value is just the load and not the impedance. right? Or is the impedance the result - 3k?
For testing Zout, you don't need the M1, the 3k, whatever. Just a current source to put current into the output. Keep it as simple as possible. Get rid of that LED stuff, unnecessarily slows down the sim.
Use a realistic load resistor to draw DC current, that is representative like 50mA or 100mA.
I can't see all the stuff at the left but you don't need to drag any rectifiers along, just put a DC source at the input.
For a freq sweep do a .ac with a current source into the output, plot the current and the resulting voltage at the output, divide to get Z.
Jan
Either way. The point is that the regulator cannot sink current. So if you ping the output with an ac current to measure Zout, you must be sure that at all times there is a net current drawn from the supply. You can use a load resistor or a DC offset in the test current source, to generate a DC load current that is larger than the ac test current amplitude at the negative phase.
Jan
Problem with LTSpice model
Hello All,
Obviously, my newbieness is showing, but I have an LTSpice subckt file entitled "vacuum.sub" (authored by Duncan Munro), and I am trying to connect some of the subcircuits in this file with the triode symbol in the LTSpice symbols directory.
I have tried opening the vacuum,sub file in LTSpice (as text), and right clicking on the name of the sub circuit, but it will only allow me to make a new behavioral symbol, and I cannot connect the 12ax7 subcircuit with the "triode.asy" file in the LTSpice symbols directory.
Can someone tell me how I can do this?
I am assuming that the tube people know what the "vacuum.sub" file is, But I can upload this file if you like (it is also on git).
Thanks,
Bob
A few quick thoughts...
A 50 ohm load has been added to take account of your 200-300ma requirement.
There isn't enough voltage differential for the 317 to operate. Increase the input voltage to 25 and see how the output of the IC becomes much much cleaner.
The rectifier diodes have been swapped for Shottky types.
Edit... there is an LM317 (LT317) model already included in LTspice. Interesting difference in simulation 😉
