The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
X,
I'll probably use it for a less current hungry Class A amplifier for the future and thanks for the suggestions. I still have to build the Alpha 20 eventually. Hugh, I totally agree with what you're saying, but just to be clear, X PM'd me about this PSU and I told him I was working on this BJX for the future. He offered some help trying to find out if it would be a good candidate for this amplifier. Although I'm very happy by how fast he got the information, I did not go on this thread and ask him to modify it for me in the first place, there was some background talk before this was posted.
Do
I have the Darlingtons on order, and if the opportunity presents itself, I will see if I can test the 7A load using a 4ohm 200w resistor. The thought of that much current going through the SLB is kind of scary but it should do fine. The ripple current in the bulk caps is what concerns us the most as it will heat the first cap up quite warm. This is a case for 105C rated caps for sure.
baswamin - 2 boards - Paid
meanie - 2 boards - Paid
jwjarch - 2 boards - Paid
gary s - 2 boards - Paid
nautibuoy - 2 SLB boards - 2 SLB-SR boards - both Paid, ship together
antoniopf1972 - 2 boards - Paid
ravid - 2 boards - Paid, Simple PSU Paid, ship at same time
Gricko - 2 boards - Paid
poseidonsvoice - 2 boards - Paid
Bkdog - 2 boards - Paid
Jazzfan - 4 boards - *Invoice sent*
yoaudio - 2 boards - Paid
van of monks - 2 boards - *Invoice sent*
Wtl - 4 boards - Paid
cerole - 2 boards - Paid
s610adam - 4 SLB - 6 SLB-SR - Invoice sent
pbergstrom - 2 boards - *need PayPal address*
ferret - 2 boards - Paid
Roundtoit - 2 SLB boards, 2 SLB-SR boards - Invoice sent
Tubesguy - 1 SLB board - Paid
Kokanee - 8 boards - Invoice sent
Arthur - 10 boards - Please send Paypal address
potepuh - 2 SLB boards
TboneAK - 2 SLB Boards
Quick heads up on the BOM posted the other day: A search for the part number for the Aavid heatsinks on the SLB BOM returns nothing at Mouser. I tried a few variations, and had no luck. The part number for the corresponding part on the SLB-SR BOM, 531102B02500G, does work on Mouser, and I'm guessing is the part intended for use on both versions.
Note that even a cheap stamped aluminum serated style fin heat sink works fine. It’s not a lot of heat so big Aavid’s are not critical. Look at my build photo to see what I did.
The big Aavids look nice though - if you really want those - get them.
754598d1557082791-slb-smooth-butter-active-rect-crc-cap-mx-class-power-supply-gb-slb-vero-build-03-jpg
Some independent testing of the SLB topology on an actual SE Class A amp. This data is provided by Vunce and voltage is 37.4Vdc at 3.925A current. Red trace is the 10R for R117 and yellow is 1R5 for R117. Voltage drop on both is about 3.2v. The yellow trace, well it’s smooth like buttah! 🙂
754786d1557146080-slb-smooth-butter-active-rect-crc-cap-mx-class-power-supply-gb-f8bc79d0-e7e6-458c-8fda-56878d157086-jpg
Vunce reported that he found the source of the hash: it was a SMPS plugged into the same mains back-contaminating the supply. Once disconnected, we get this front he SLB (too is with 10R and bottom is 1.5 for R117):
attachment.php
GB Status Update:
s610adam - 4 SLB - 6 SLB-SR - Paid
Roundtoit - 2 SLB boards, 2 SLB-SR boards - Paid
Kokanee - 8 boards - Paid
Arthur - 10 boards - Paid
potepuh - 2 SLB boards - Need PayPal address
TboneAK - 2 SLB Boards - Need PayPal address
Sanjeevm - 2 SLB Boards - Invoice sent
GB Status Update:
potepuh - 2 SLB boards - Invoice sent
TboneAK - 2 SLB Boards - Invoice sent
Centurion53 - 2 SLB boards - Invoice sent
Vunce - 2 SLB boards, 2 SLB-SR boards
