Krell KSA 50 PCB
Have you tried this!
You all probably have done this already, and sevaral times as well: Check all the resistor values one more time.
With a friend of mine I was building the Pass Aleph 5 amplifier. My friend was hitting the wall with his amps, the same symptoms showing on both channels.
We discussed and looked at the diagrams and back to the boards with no luck. In the end I took the PCB, my friend took the BOM and then we checked all the resistors, reading the values AND colour codes out loud. And there it was, a 1% resistor with multiplier ring being RED instead of ORANGE.
Today the Alephs are finished and plays just fine!
Errors repeating itself on 2 boards are probably man-made. Like component values, switching NPN and PNP, turning transistors 180 degrees, earth loops.... (I won't even mention once I forgot the transformer when I hooked up an amplifier for testing. I checked "all" connections and tried again. Lights out again. Now I am very catious about the transformer...)
Good luck!
Reactions: tschrama
This is where your fault is.
If the pot is set to centre position the wiper should read 0V (meter black lead connected to 0V).
Refering to the pic, D1 & D2 each drop about 1V, the diodes centre connection is nailed to 0V; looking at the divider chain (2x 4K7 + 5K pot) across the diodes, the pot is aprox 1/3 of the total resistance - meaning that the pot wiper will see 1/3 of 2V or -0.66V to +0.66V (roughly).
Hi itsmee thanks for your help but I am still confused D1 is 4144 diode on +48v line I get +.55v one side of this diode and +0.0v other side.
D2 27v z diode I get +26.7v one side of diode 0v other side.
D3 diode is 4144 diode -48v line I get -46.7v one side of diode and -9.3v other side of diode.
D4 is 27v z diode I get 26.7v one side of diode and ov other side of diode.
Is it my diodes which are wrong 4k7 resistors / 9k1 resistors or ksa1845 /2sa992.
Resistors are correct by the diagram though or should I try some 2SA1312BL/2SC3324BL smd transistors.
Pictures Dave, pictures 😉
Pictures where we can see the values of installed components.
Thanks neychi I did check every resistor with a meter as well and all seem to be ok.
Good luck!
Thanks m0rten, I did do the transistors in wrong possitions at one point pnp & npn in wrong possitions.
In my difference I got the part numbers muddled up as they was not original part numbers.
Also managed to have my b+ terminal move and touch -48v blowing my output stage and some resistors.
I have removed one side of each transistor and measured it with a meter just to make sure they was reading correctly.
As you say its strange that both my boards have exactly the same problem.
Its probably something I have done wrong and will feel stupid when I find it.
The -9.3V end of the diode should be 0V, check the continuity of D3 anode (top end in schematic) to 0V.
Thankyou again itsmee you are correct my D1 D3 have not got 0v to them.
I have checked all solder joints but nothing is faulty.
Should I run a wire to these diodes from 0v ground in.
As you can see both boards have a make do joint from diode to -48v I did not do this they come like that.
Dotted line is the diodes
