Studio Reference Amplifier
SR20
Finally SR20 is complete after long time( two months 🙂 ).
Apex Sir,
What is the Gain of this amplifier with 75-0-75 VDC power supply?
Hi Samratsarkar,
I take the liberty to answer your question 😉
Gain does not depend on the rails voltage, it depends on the feedback divider's ratio. Referring to the schematic in post #2884:
Gain = R14 / R15 + 1 = 47K / 1K + 1 = 48
Gain(db) = 20 * log (Gain) = 20 * log (48) = 33.6 db
Valery
Hello friends, Finally I Test SR20, it sing 🎤. In First run bias 14mv, dc offset +/-1mv. Power feeding with +/-42v DC. With this setting I play music 🎶 2houre. Sound is nice and warm. In second run bias stable but DC offset shuffling on +2 to 2.5 mv (not more then 3 mv). Is it ok?
In both time O/P transistors little hot, but pair of BD139 is little hot compare of BD139/140. Any issue with that?
One more thing, Is SR20 need pro if yes which protector we use. Sorry Mr. Miles for throwing some questions 😃😂😂.
Gurpreet
Gurpreet
Nice work, DC offset is very good, use PSU100 there is protect.
YouTube
YouTube
Thanks Mr.Miles for FX100 PSU.But Today I m busy with second channel of SR20 DC offset 4-8mv. One time its go on 15mv. Is it ok.
Second issue with pair of BD139 and TIP147 more hot compare of TIP142 in both channels. Why ?
Can I use heat sink for both BD Transistors.
Above thing are normally Rise in mind
Because Discussion on SR20 - nothing. Sorry for selection on (may be ) words.
Gurpreet
Gurpreet
Offset is ok, what about bias (voltage on 3x1R2W resistors)?
Measurements must be with input short to gnd, yes use heatsinks for BDs
During install heat sinks on BD's some resistance are burnt and a capacitor pop up( mark with red in blow pic.) on one board. After replaced faulted components bias stable but DC OFFSET SHUFFLING 10-20mv. Other measured volts also stable like
2.3v across capacitor 220nf,
.65 across resistance 68ohm
.58 across resistance 120ohm.
One more thing these results are with open and short input with GND
With bias 10mv and series with 100w bulb.
If we bias set on 15mv after some music played on full volume bulb little bright then bias checked its 100mv its going down too slow. Speaker 8ohm well work, 4ohm put stress on amp and bias get very hot immediately.
Any advice plz. .
Gurpreet
Change position for heat sink
Heat sink on BD transistors is little headache for me. So I make some change on BD transistors position for heat sinks, please check for errors. But BC109's PCB design is very nice and compact.
Gurpreet
