Maximum operating hours
I notice that the ACA gets hot easily. Is there a recommended maximum operating hours for this good sounding amplifier to avoid overheating?
Just measure the heatsink temp. Around 50c is okay forever. This was just discussed a page or two back. So there is a bit more info if you search.
ACA's and heat
Have run mine 24/7 for periods of weeks. They get to a certain temperature and stay there unless the room ambient temperature changes. Just make sure air can move under them and around them.
I know what gauges I need. Can anybody identify what type or brand the wires for the kit are? Or simply identify some quality wire for power, signal, and output?
Udailey, thanks!Just measure the heatsink temp. Around 50c is okay forever. This was just discussed a page or two back. So there is a bit more info if you search.
tjw29, thanks!Have run mine 24/7 for periods of weeks. They get to a certain temperature and stay there unless the room ambient temperature changes. Just make sure air can move under them and around them.
I have one of the original kits, I have not shut it off in about 4 years now. Well occasionally it gets shut off to move or clean, but mostly left on.
Billy, thanks! It only goes to show how durable the parts are.
I am done building my two monoblocks. My Q Acoustics Concept 20s are perfect for the ACA. I have not yet tried them though with the Magnepans.
Bear in mind that I've barely made apprentice amp builder status and that I'm not blessed with golden ears - in my case, I opted for generic offerings. The important factors that I looked out for (after gauge) was (in no particular order):
- Solid versus multi-strand
- Tinning of the copper wire strands
- Temperature rating of the insulation (if you're concerned you can take this to the next level and check the build/design standard)
Hook up wire can attract a swag of opinion, e.g.:
Best Hookup Wire? (for component internal wiring)
You could check that thread to gather intel. Probably best to avoid sending this thread on a tangent.
Good luck with your journey.
Way off topic, sorry!
Uriah, it made me smile to see your name in a recent post. I still fondly remember our past dealings and hope you and yours are doing well.
Back to our regularly scheduled program.
Hi, guys! Is it worth it to use a cable with RCA input or stereo 1/4 plug at one end and a balanced output at the other so that I can use the balanced input in the ACA? I will be using a cd player with no balanced output or mobile phone as source.
Just built up and ACA. Looking at the amp in bridged mode using RCA input as per
. The input and output are the same polarity.
When the XLR is used pin 2 (+) connects to the R input and if the speaker is connected as above the the input and output polarity are out by 180 degrees.
Am I correct in my observation?
I wrote a very lengthy explanation why it is not so, and while doing it I think you may be right.
Rembmer that each ACA channel will invert the phase.
So... in bridged mode, the black cable is hooked to the same channel as the input (left) which will be reversed, and that output (which is inverted) is input into the right channel which is re-inverted (correct original phase). So, as you mention... that will yield correct absolute phase in the speakers.
Now, in balanced XLR, you should get the same thing...
So, the hot pin (pin 2) will get inverted, so to preserve absolute phase, that should go to the 'black' output. So pin 2 should go to the left channel of the amp, but it is connected to the right channel of the amp.
Maybe I'm missing something obvious, but I think you may be right here. 🙁
6L6? You are the master here, what are we missing?
Rafa.
Rafa.
With a balanced source. The inputs to pin 2 and 3 of the XLR are equal in amplitude but opposite in polarity. Its purpose is really to reject noise in high noise environments. It could be debated for years as to whether it sounds any better. And, for those that love the 2nd harmonic distortion of the ACA. Using it in the balanced configuration, cancels the distortion.
A good diy project that would really help one to understand it would be an unbalanced to balanced converter amplifier.
It is because the balanced source is equal in amplitude but opposite in polarity that you use the two (-) speaker posts: to feed your speaker. Rather than a single end playing against ground. Each end plays against each other. Doubling the output amplitude and canceling the noise.
In that mode you don't hear the turn on growl - because the noise is cancelled. Or CMR. Common Mode Rejection.
But isnt the noise that's canceled using balanced lines all external noise, rather than internal noise from the amp? I'm confused.
I think you are right - in XLR, as you say, "red" (pin 2, hot, standard phase) will get inverted by the amp, so that should be speaker black.
Pin 3 ("white", reverse phase) will be inverted by the amp, and should be speaker red.
Of course, the output is taken from both of the black speaker posts.
SO...
If my thinking is correct, the photos in the guide (for XLR) are incorrect...?
But here's the thing... Absolute phase is best tested in your system, and you choose what sounds best to you. I had a friend over recently, listening to his new factory-made SIT-3 (fantastic amp, as good as you can possibly imagine) and then we switched to the M2x with Norwood buffer -- it sounded really good, enjoying it immensely, holding its own against the SIT-3 quite well. But I was listening to a recording I've known since I was a child (and never get tired of) and thought something wasn't quite in the right spot... So I reached down, inverted the speaker wires, and immediately my friend shouted out "Wow! What did you do??" because it sounded about 98% as good as the SIT-3.
Both amps are non-inverting. Sometimes things don't make perfect sense.
- Amp Camp Amp - ACA
