Hard to tell from your image but did you mount your board with 3 standoffs and pinch the board with washers and screws?
I worked on mine over the weekend using the kit kindly supplied by 6L6.
It's not quite done yet since I have yet to test it. I hope to be able to
do that this coming weekend.
Dennis, whadda you hear, whadda you know? 🙂
It wasn't really designed to drive anything in particular more of just a experiment. It will drive quite a few things though especially with the bigger outputs.
Perfect.
Thank you.
Yeah that's what I did. I used the ones with the threaded post on
one end and the board rests on the standoffs snugly agains
the post. (Added a nut first to give a big more area for the pcb
to rest on) Then another nut to tighten things down a bit.
I was going to add a 4th standoff but so far it seems fairly stable.
Dennis
I also finished mine yesterday and listened with it for a couple of hours. Sounds really good with nothing nasty to report. Straight forward build. The best part of my build is that I had everything in stock and did not have to order anything else. My regulated supply is just an Ebay Chinese one that works fine. Bud box I had laying around that was never used along with a 15V toroid. I just used hot glue and some wood blocks with a grove cut in them to mount the boards. I so not expect any problems down the road from mounting them that way. I plan on finishing up the build today, hooking up a switch on the input to use two sources and doing some testing.
Looking good Dennis!
Nice!
I just finished running some test on my build. The sine and square waves were excellent on my scope up to 20K, where I stopped. Using the Arta software distortion and noise were at the lower limit of my test setup. In other words much as what Wayne described at the BAF. Sound stage is excellent using my BA-1 amplifier. I like SE amplifiers.
I almost forgot to thank Wayne for generously working up the circuit for us diy'ers and Jim (6L6) for going the extra mile making the kits for us as well. My understanding is he is a pilot in the Air force so making the kits is just a hobby for him. A lot of effort goes into ordering all the parts and separating them for individual kits.
I hope our store decides to stock the boards as well. Linestage's are something lacking in the store. I know we have the BA3 front end boards to make a linestage but after building a few of them I would call it alright, nothing special. My LSK linstage presented by Nelson at the BAF is much better. How it compares to this one is something I will have to find out.
Again, thanks Wayne and Jim.
You’re welcome for the project. It will be a more complete project soon for the store. I have lots of irons in the fire these days. Nice seeing successful builds.
Jim is a corporate jet pilot and advises me on all flying related questions.
Now I am a fan of "wizards assistant', Wayne!
If I compare the sound to drinking, I get too drunk to talk about the liquor. 🙂
This let me enjoy music more. 😀
Wdecho - I have, but obviously can’t A/B it as the ba3 used to be in that very chassis... and I think I like this one better. The ability to drive headphones (using the big output transistors) is absolutely worth the change by itself. My headphones are 25ohm and it’s got zero issues at hearing damage levels, and sounds fantastic at reasonable listening levels.
The blue Broskie supply was +/- 24v, worked beautifully. The new red Broskie board is set to +/- 18v, and also works great. The red board is a little quieter, I think, as it’s a blacker background kind of thing instead of a less noise thing. (If you know what I’m getting at...)
Labjr- I will try the Silent Swicher powered by a battery pack, does that count? I sorta think so... 🙂
BA3-pre also have large output transistors and even needs heatsinks so should think BA3-pre can drive headphones? …..or it is because Wayne linestage has lower output impedance caused by NFB that makes them better "headphone drivers"?
- Wayne's BA 2018 linestage
