Here is my version. 😀
Does sound very good. Have a VAC (tube) preamp and the sound is very similar - the B1 Nutube maybe being a bit more articulate and having tighter bass. It definitely is in par, even with the basic switching power supply. No critical listening done yet though.
A big thanks, Nelson!![]()
Good thinking from Finland. The Nutube is sensitive to vibrations and wood has a nice resonance for audio. Don't burn your house down. 😛
Nice work, builders. Plenty of inspiration on show, thanks for sharing.
I've ordered the Nutube accessory kit from RS UK. I think it's the daughter board and perspex cover that I posted a picture of a while back, but I'm not too sure as there's no description or photo on the RS website. At ~£11 with free delivery I felt it worth investigation.
I will report back when it arrives.
Would anyone care to share an opinion on hot glue vs. Silastic vs. acoustic felt vs. Sorbothane, for Nutube vibration damping?
Pass DIY Addict
Joined 2000
Fugly!
Looks great 🙂
How did you get the lettering on the front panel?
Digital printing from the DIY Store -
Digital Printing – diyAudio Store
jugi63, qwertyl, what type and brand of rotary input switches are those?
thx
ELMA 4 pole 6 way switch
My B1 Korg preamp is using the proper board now and it sounds awesome with my M2 clone 🙂
Tell us more about those Jensen transformers. Is it really a good idea? Is the goal to make them balanced? Is this the best way to do it?
thx
A Lorin Electronics silver plated contact switch. Something like this: CK – Lorlin Electronics
Korg preamp PCB
Sorry if this has already been asked and answered, I did a search but didn't find anything specific. I would like to build one of these and started to order a Nutube but thought I would make sure that a PCB will eventually be available in the diy audio store?
Here are some pics of the final build. I went a little overboard on this one so it's a bit of overkill but I'm sure nobody minds that.
The PSU is a Sigma 11 24v regulated supply.
The volume control is a Khozmo remote controlled attenuator
I got the Nutube and carrier board from Pete Millet
The input selector is the Select-2 from Tubecad
I still need to glue the plexiglass inserts on the front panel but haven't gotten there yet but it will be smoked glass on the front.
A couple things I need to work out - My input selector pops. The other thing is that I have an Intel NUC -> DAC -> preamp and I can hear a slight buzz when the CPU is working. It wasn't there before but now I can hear it. I can't hear it while playing music but can when nothing is playing. Probably some sort of grounding thing.
Anyways, it sounds great. I have it hooked up to an F5 and it makes the bass much stronger (didn't expect that) and almost 3 dimensional but has a slight echo in my ears on the low end.
Thank you Mr. Pass !
Kevin
Nice build Kevin!
Nelson addressed the input selection pop on the original B1 by adding 1 megohm resistors across each input. Like you, I too used the Glass-Ware Select-2 but decided to tie all the input grounds together, rather than switching grounds individually, and adding the 1 meg resistors to avoid the pop.
Just turn down the volume before changing inputs and everything should be great. 😛
Enjoy!
Bravo Qwertyl! High Quality
Nice build Kevin!
Enjoy!
just use shorting one (Make Before Break) and no PoP
trick old as Earth
each Lorlin , if shorting , is having big letter S somewhere between pins
read datasheet for more specific info about S and non-S
I believe the most recent answer to that question is here
If you're interested, it might be worth reading the entire thread. Many questions will be answered.
Jensen transformers... It's a long story. Ages ago I built 2 F4s and I was planning to use them as mono blocks driven by Impasse preamp. I started collecting parts, bought Jensen transformers, etc, but then I converted one of my F4s into Aleph J. I used balanced output of my DAC to drive Aleph directly. The second F4 was converted to BA-3 power amp and I built BA-3 preamp in a separate chassis. I had an idea to use Jensen transformers, which were gathering dust for a few years, as balanced to unbalanced converters on the input of my BA-3 preamp. It worked fine, but then I converted BA-3 power amp into Sony VFET. And so on and on and on... What used to be BA-3 preamp is now B1 Korg preamp. Jensen transformers are still there, and they probably work fine as balanced to unbalanced converters, but I don't use XLR connectors at the moment.
- B1 with Korg Triode
