Digital Tachometer for record player (LCD display)
Hi find my tachometer completed, I have ordered ZeroZone linear power supply for my turntable motor, I build my tachometer (Midas LCD+ Arduino Uno) inside linear power supply. Thank you all helping build accurate turntable tachometer. Rajkumar
Not trying to hijack the thread.
I just checked HiFi Heaven website to purchase another of the sensor module.
Glad to see they are still around.
I will however say, it is sad to see the Roadrunner and the Falcon still listed but, unavailable.
Glad I have them in my system.
I have been following this thread with great interest . Really great to see this come together and brilliant of Pyramid to share his code & expertise . I've built an RG4 so now on to this 🙂
I've got the Arduino , OSHPark Sensor PCB's (which I am just building) . and am about to buy these displays
MUZOCT IIC/I2C/TWI 1602 Serial Blue Backlight LCD Module for Arduino UNO R3 MEGA2560: Amazon.co.uk: Computers & Accessories
Do they look about right ? I just need to add that display type to the code ?
Thanks all
@raymondo- It's I2C so it should work, you just have to make sure you have the right address (use the Scanner script in post #307 to find the address if in doubt) and it doesn't need a negative supply like the Midas module; if it does, you will need to mod the display.
ok great thanks bill - everything is ordered so I will give it a go in the next few days. do i need to do something to the line
LiquidCrystal_PCF8574 lcd(0x3f);
in the code once I have my display apart from change the address to whatever mine uses?
I think for that type of display with the I2C adapter installed you need to do like this.
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2)
The second line you must set the address that it maybe Ox27 or 0x3F. and how many characters and how many lines.
Ok so I've got the display working and tested with a hello world sketch
But when I try and complile the tach ino i get this error
Using library LiquidCrystal_I2C-1.1.2 at version 1.1.2 in folder: C:\Users\braymond\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2
exit status 1
expected ',' or ';' before 'const'
The line highlighted is the first one
const int TRIGGER=3; //* input on PB3
I'd post a screenshot but cant work out how to do that !
Any ideas ?
Did you copy tach.ino from a file or from a screen shot here on DIYAudio. The screen shots will randomly omit characters.
The error may be at the end of the previous line; is there a semi-colon after the lcd declaration:
you were right it now looks like this
LiquidCrystal_I2C lcd(0x27, 16, 2);
and compiles and uploads fine - but - nothing happens . I've not got the sensor built yet but figured it would still display something .
so for example if im running the hello world scrolling program and then upload the tach one it uploads but the display freezes and then nothing happens . It is definitely uploading fine.....
