LM3886 Schematics + PCB
Image File
Image File has been uploaded. Plz let me know incase of any mistakes
I've built this pair of Gainclones. Just waiting for the transformer in order to start the tests. It was very challenging to me. I din't have a Dremmel, so I fixed the driller into a stand and handled the PCB to drill it using mini drills. Also I found the trails and Isles very near each other. Very affraid to short circuit them when soldering.
LM3886 🙂
What is the configuration of your transformer. How much it costs. I have the gerber files, if you like then you can use it, bit big compare to APEX version. 75mm x 35mm but the Same design.
Nandhakumar
Special Thanks to Mile and Prasi and Other Friends
Hi Mile / Prasi and Other Friends,
With a great pleasure, i like to inform you that both Gainclone and Super Gainclone are working fine. Finally, i am going to use Super Gainclone for 7.1 amp. with 500w subwoofer.
But as i have designed using diptrace size become bit big(i am a newbie). 68mm x 31mm it become.
Is there any option to bridge/parallel these boards to get 100w RMS ?.
Thanks and Regards,
Nandhakumar Vemban
Reactions: NemanjafromSerbia
