John Curl's Blowtorch preamplifier part III
The same amp, one ClassA output mosfet power consumption at 170W/4.
The worst example of ‘feedback is bad’ I’ve seen is on the Audio Note website. All the usual feedback tropes are there - clearly Colloms acolytes.
Amplifier designers who eschew feedback would do well to remember nature abounds with it. Just take a look at the metabolic pathways in a living organism, or try to explain stellar nuclear fusion in a stable main sequence star like our sun without it. Good luck on that one . . .
Feedback: A Short History
Audio Note is now "working with" eVGA to make a crappy PCIe sound card which isn't even native PCIe. Not to mention it uses op-amps (and poorly chosen it would seem, at that).
Could you please show the result for 4ohm load at various amplitudes? 8ohm load is unrealistic, I do not know a usual speaker that would have impedance equal or above 8ohm in the whole frequency range. I know that 8ohm results are nicer, but for the real world, useless.
The minimal impedance value of a speaker is its DC resistance. Usually 6 Ohms for a 8 ohm speaker.
An ideal speaker should have a flat frequency curve AND a flat impedance curve. I do not understand why almost all the manufacturers neglect this last point. And it is sooo easy. If you have tried by yourself, with appropriate RLC and LC networks on each speaker of a multiway cabinet, comparing measurements and listening experiences, you'll never go back.
One other advantage is it helps to calculate the passive filters and It should help the marketing departments, showing the near flat impedance curve, to argue about the absolute superiority of their product with their usual BS ;-)
I am sorry but in a multiway speaker it is a combination of drivers impedance + crossover circuit and impedance often goes to 2 ohm at some frequency. I believe you are only joking. Please check some measurements of speakers in Stereophile, or measure yours, if it is not a single driver without crossover. Sometimes I really do not understand some replies here.
SOTA -
Seems no one here has read the book by Kolinummi? Nothing to do with is GNFB good or bad. Instead, an extremely linear circuit can be designed that does not require GNFB. I would imagine if you then add GNFB to it, the results will surely be stunning.
The effectiveness of adding an Error Correction FB is shown to be VERY effective.
Also, notice the comment that the design being shown by the author is very DC stable such that a DC servo would not be needed.
IMHO This is SOTA and I want to listen to such.
THx-RNMarsh
I am not "joking", as you says in such a gentle (and usual) way.. Just I don't care about bad designed enclosures or dishonest specifications.
Whatever you want to achieve, with passive filters, there is NO technical reason why you should go under the DC value of the speakers as a result, amplifier side.
If you use one 4 ohms speaker in a 8 ohms cabinet, it is dishonest to pretend it is a 8 ohms cabinet. And if somewhere in the impedance curve of a finished cabinet, you can see a frequency where impedance is 2 ohms, it is dishonest as well to pretend it is a 8 ohms cabinet.
EOT for me, I take no pleasure to argue for nothing.
The IEC standard is minimum impedance should be greater than 80% of the rated impedance.
The AES version is 50%.
And of course there are folks who pay no attention to the standards.
Home theater amplifiers often self protect below 6 ohm loads. I once had a professional amplifier that had problems at a real 4 ohm load. The manufacturer discontinued that model.
I recently ran into problems trying to explain to a consultant that professional loudspeakers do not require damping factors greater than 10. The electrical code assumes that if you are running power limited tray cable above 12 gauge, it is driving a hazardous load.
